Old Mon 17 August 2009, 21:24
Besser
Just call me: Besser
Vic
Cutting Flatout! - monitoring and optimising the current drawn by the spindle/router
Something I came across in my travels in and out of CNC workshops is the load feedback loop. Can we or does anyone incorporate this into MM use.
This feedback loop measures the load on a motor by how much current is being drawn, for 2 functions.
1:Used to determine the maximum cutting load possible for the motor rating (eg full load current (spindle or router and possibly steppers for feed rates) This means you can start to maximise your cutting speed and reduce part completion time.
2: Monitor bit quality. For repetitive cuts a history of load (amps) can be mapped and applied to the live cut, as the bit starts to wear and blunt then the current draw for the path increases and the software can flag a warning or stop. Additionally if a spike (up = tool jam, down= tool break) occurs then the machine can auto shutdown.
I intend to hook up a VFD and want to look at incorporating this principle so if someone is already doing it here, I'm happy to follow the leader.
Transformer supply current versus Gecko output current . . . . . Mike Richards 702. Power Supplies 42 Fri 15 January 2010 04:37
High End Router or Spindle, which way to go? kanankeban 50. Toolheads 14 Thu 02 April 2009 23:54
Router Spindle Recommendation? robertmonroe 50. Toolheads 1 Thu 04 December 2008 02:00
Router / Spindle cable management gmessler 60. Wiring & Cable Management 1 Sun 19 October 2008 19:01
Where can i get full cad drawn like the pdf file eloid Archives 12 Mon 14 May 2007 10:37
