Old Mon 13 April 2009, 22:13
osman100
Just call me: osman100
giza
Egypt
dear Gerald
u are right but how can i put this delay
Old Tue 14 April 2009, 02:29
In G-code,
G4 (or G04) = Dwell
P = Period of dwell, when used after G4 (P can have other meanings depening on context)
G4P60 = Dwell for 60 seconds (unless you have changed it to millisecond (Config/Logic, middle column, check box for milliseconds))
You can try this for a test:
F1000 (i.e. faster than possible but Mach3 will limit speed)
G20 G90 (Inch and Absolute)
M98 P1234 L50 (run subroutine 50 times)
M30 (stop)
O1234
G1 X4
G4P2 (stop for 2 seconds)
G1 X0 (do a feed rate move and move back)
M99 (return)
Old Tue 14 April 2009, 02:35
You can also try Config > State:
....but I don't think this will make a difference for that simple program.
Old Tue 14 April 2009, 09:09
osman100
giza
Egypt
thanks i'll do then let u know
Old Wed 15 April 2009, 14:13
osman100
giza
Egypt
dear Gerald
i start today to test the machine but i'm very surpriues because when i change the feed rate i found the distance also change acoording to feed rate vatue can anyone help me
thanks
Old Wed 15 April 2009, 20:39
Osman, your application of Mach3 with a VFD is very unusual, and I think your best help will come from the Mach forums at:
http://www.machsupport.com/forum/index.php
and
http://groups.yahoo.com/group/mach1mach2cnc/
Your Omron controller is actually produced by Yaskawa:
http://www.yaskawa.eu.com/index.php?id=185
Old Tue 12 May 2009, 10:59
osman100
giza
Egypt
dear all
thanks for your help and I'm sorry for long time to contact you but rely I'm busy to adjust my machine with this type of inverter . it isn't easy but by the the end and after long fitting today i just finish to adjust x axis and I'm rely succeed 100 % INSHAA' ALLAH
as i told u before now it's work as servo but to reach this that's very important point
1- make motor tuning to adjust motor with encoder and inverter and this tuning should be running tuning
2-adjust pg parmeter
3- adjuster ASR parmeter to adjust feedback from encoder
4-use mode v/f with pg feedback
5- adjust v/f curve and parmeter
thanks for all
Old Tue 12 May 2009, 22:44
Mabruk! Thanks for the feedback.
I would really like to see some pictures (or even a video?) of that big machine.
Old Sun 17 May 2009, 07:35
osman100
giza
Egypt
thanks sure I'll send u photos and Video but i prefer when i finish
can u help me for the accurate and best way for home switch r it limit or proximity switch or photocell or other
Old Sun 17 May 2009, 09:16
Have a look at this long thread: Limit Switches - optical / mechanical / proximity There we have a long discussion about different types of switches and how to use them with Mach3. However, we conclude that proximity switches are the best (for dirt and accuracy), but it is a little tricky to use them in series for Mach3. The trick is use a little electronics with the proximity switches, or even just use a simple small relay. In your case, with water and mud, the proximity switches should really be the best.
