Old Sun 25 January 2009, 18:29
jvfc
Just call me: Vladimir
Curitiba
Brazil
Send a message via MSN to jvfc
First cut. 2mm end mill
http://www.kapbrasil.com/videos/mechmate02.wmv
more pics.
hugs
Old Sun 25 January 2009, 21:47
I wish I could have been there to see it!
Congratulations!
Your video shows a fairly small cutter mounted on a standard AC motor and it cuts at quite a good speed . . . . . . very interesting. . . . .
Old Sun 25 January 2009, 22:01
Can you show us photos of the cutting quality you get on the edge of the MDF with a 6mm cutter when you cut about a 100mm diameter circle? People say those big motors are not good, but the end of your last video shows a very fast and controllable machine. The only question now is the cut quality.
How does it compare to this, where we had direct drive with a smaller motor?
Old Mon 26 January 2009, 14:18
jvfc
Curitiba
Brazil
Hello Gerald, I make a test of the circle and square. both 100mm with 6mm cutter and 2500mm/min.
the measures show me accuracy.
hugs
Old Mon 26 January 2009, 21:56
Thanks for the pictures. Is that maybe about the same as what we saw at 80 mm/second (4800 mm/minute) with the shorter motors? I know it is very difficult to compare by photographs alone.
Old Sat 31 January 2009, 19:05
Vladimir,
Congratulations on your build. Gerald as added your build to the Builder's Log.
The updated Builder's Log is here.
Please tell me how big your table is. For example what are the dimensions of the spoil board I see on your table?
Also, when did you actually start the build? Your first post was on 10-Jan-2009. But I think you had already been working on your MechMate before 10-Jan-2009.
Finally, you will notice that your entry is not bold and that you do not have a serial number. I think that you almost qualify for a Serial Number. I think you only need to add MechMate Logo's to qualify. Of course, Gerald is the one who makes the decision to award a Serial Number, but I wanted let you know how close you are to earning a Serial Number. I'm currently building a MechMate and when I get it completed, I will be anxious to earn a Serial Number.
Regards,
John
Old Sat 31 January 2009, 19:50
jvfc
Curitiba
Brazil
Hello, I would like much a serial number.
we started the build 04-may-2008.
table measures standard 2750x1883.
soon the MM logo's may be fixed
Best wishes
Old Sun 01 February 2009, 06:49
Thanks for the update Vladimir.
I hope you earn your Serial Number.
Regards,
John
Old Sat 07 February 2009, 16:56
jvfc
Curitiba
Brazil
hello, today we make drilling on table, to fix nut with claws. video below
http://www.kapbrasil.com/videos/furando.wmv
hugs
Old Sat 07 February 2009, 18:12
Wow that machine looks really good. The videos are very impressive. I think all you need now is some decals and the serial number should be in the bag!
Old Thu 12 February 2009, 03:37
Valdir Fernandes da Cruz
Just call me: Valdir
Curitiba - Paraná
Brazil
We needle to install the cable chain and to fix the Mechmate logo.
Where i can to find the standard Mechmate logo?
Thank you
Valdir
Old Thu 12 February 2009, 03:54
Official MechMate logo and colour
Old Wed 25 February 2009, 11:25
jvfc
Curitiba
Brazil
just cable carrier Installation
Old Sun 01 March 2009, 21:17
jvfc
Curitiba
Brazil
Hello Folks, two works .
http://www.youtube.com/watch?v=4Y8NUK_tbi8
Old Mon 02 March 2009, 04:02
Vladimir - I am amused at the way you hold the parts - with something as big as a Mechmate its quite difficult.
nice work though
Old Mon 02 March 2009, 06:04
Vladmir I sometimes use the same principal, except I use small sticks 18" or so long. I have cut the ends off by mistake several times. If you continue this hold-down method you will too. All I needed to do was cut more sticks. What will you need to do ????????????????????
Nice cutting machine
Old Mon 02 March 2009, 06:28
I will answer that -replace finger tips
Old Mon 02 March 2009, 06:43
jvfc
Curitiba
Brazil
Thanks!
I don't like a long stick, but it is necessary . very danger machine.
Old Mon 02 March 2009, 06:59
I don't like shortened fingers
Old Mon 02 March 2009, 07:03
gixi
Bucharest
Linear Guideway
Hi Vladimir,
I'm curios how Linear Guideway takes the forces when you cut material like wood for example? Does those guideways resist in time and for how long ?
Because when you cut along X and Y axis there are a lot of force in order to push through material.
Thank you,
Marius
Old Mon 02 March 2009, 07:47
jvfc
Curitiba
Brazil
Marius, you question is about linear guide that I use in my Z axis?
My linear guide of the 20mm:
charge= dynamic capacity is 14.1 KN
charge =static capacity is 24 KN
Old Wed 22 July 2009, 16:49
jvfc
Curitiba
Brazil
hi all.
I would like to sharing this incredible work done by machine called mechmate .
logo mark of our workshop, this will be internal environment.
hugs
Old Wed 22 July 2009, 17:54
Outstanding graphic design. Very professional.
Old Wed 22 July 2009, 18:34
Looks Great!
Old Wed 22 July 2009, 21:04
Good to hear from you guys again! Looks great!
Old Thu 23 July 2009, 18:03
jvfc
Curitiba
Brazil
thanks guys, more news soon.
Old Thu 23 July 2009, 23:08
Lex
Just call me: Johan #56
Empangeni KwaZuluNatal
Hi Vladimir,
How is your motor and z-slide holding up? Are you still happy with the cut performance?
Old Fri 24 July 2009, 14:03
jvfc
Curitiba
Brazil
The cut is not as good, but for major work is acceptable.
soon we will use 3:1 reduction.
hugs
Old Sun 26 July 2009, 16:27
jvfc
Curitiba
Brazil
small video of that great machine in action.
http://www.kapbrasil.com/videos/artech.wmv
Thanks Gerald!
hugs.
Old Mon 27 July 2009, 09:11
jvfc
Curitiba
Brazil
I would like to share my last build, my cnc design
http://www.kapbrasil.com/videos/cnc3.wmv
hugs
New MechMate painted, with experimental control box - Atibaia, Brazil zetacnc MechMates already cutting 48 Tue 13 July 2010 00:37
Hello From Sao Paulo, Brazil! luizfrds Introduce yourself and start planning 13 Tue 30 June 2009 16:21
Mechmate for guitar making? rhoads56 General - MM Build 7 Tue 19 February 2008 12:03
Many steel parts cut - Curitiba (PR), Brazil ldorta Construction started, but not cutting yet 20 Thu 01 November 2007 01:13
