Old Fri 10 October 2008, 18:27
I am happily driving 2 x axis motors off a "shared" dir/step channel so the 4th axis on the PMDX can be used to drive the 4th axis. ALL works very well and no issues to date. Almost 10 months of hard work out of my machine thus far - perfect.
Old Fri 10 October 2008, 23:36
For those wanting 5 independent drives from the PMDX-122, I believe a 5th drive could be configured for step and direction off connector J8 at the top right:
There you have a GND and +5V, which could be the COM for G203 (GND) or G201/2 (+5V) drives. Mach3 can be configured to give the Step/Dir pulses on either pins 14 & 16 of that connector J8. Havn't tested it myself, but it seems feasible?
Old Sat 11 October 2008, 02:44
But then G' we need more outputs for the Spindle control
Me and Vishnu have opted for a serial interface based board for spindle control
http://www.soundlogicus.com/SPINDLEC...6/Default.aspx
RGDS
Irfan.
Old Sat 11 October 2008, 08:01
We use the J7 connector (bottom right of the PMDX) for spindle on/off and a simple potentiometer and knob for spindle speed (like a volume control). Mach3 turns the spindle on and off, while the operator picks the speed manually to suit the material hardness and the cutter bluntness. No extra board required.
Old Sat 11 October 2008, 08:55
hmmm G' you were too late to mention this - I already ordered two of those spindle control boards
RGDS
Irfan
Old Sat 11 October 2008, 09:33
How did you think we controlled the spindle? By the way, the digital readout of the VFD shows the speed dialed by the potentiometer knob. It is a very simple setup.
Old Sat 11 October 2008, 10:46
I thought u had a manual on off - and yes I look at it now - my mistake completely - but anyways it might be good to have a automated control over speed, another parameter less to be concerned of.
Old Sat 11 October 2008, 11:23
. . . . . . . more likely another parameter more to be concerned about during programming.
When you cut a test pattern first in MDF and then in oak, do you really want to have to change the program?
Old Sat 11 October 2008, 12:27
hmmm.......
don't worry then I will use the pot then - G' let me self justify the purchase of the spindle control board
but you are tight too - a fact is a fact
Old Sat 11 October 2008, 14:06
I can see where programming the speed can be useful, such as when cutting across the grain versus with the grain, or a V-cutter going fast on a shallow cut and slower on a deep cut. But everybody seems to program one speed at the beginning of their cut file and don't change it again.
Old Tue 19 December 2017, 10:21
IamDave
Just call me: Davey
Ball Ground, GA
And almost 10 years later, it still holds true.
