Old Tue 12 August 2008, 05:26
sprayhead
Just call me: Francis
sydney
Does dust get stuck in V-Rollers or on the rails?
Anyone has had problems with lots of dust on the wheels/tracks?
Or, does the Dualvee system really doesn't mind dust?
thanks,
Francis
Old Tue 12 August 2008, 06:45
Some plastics (making static electricity?) do sometimes attach themselves to the rails and form a thin "crust", maybe 0.5mm [0.020"] thick, but it flakes off before it gets any thicker. Never had to stop a job because the rails needed cleaning. Have however had a buildup in the z-rack while cutting a "sticky" plastic and not having any dust extraction at that time.
Old Tue 12 August 2008, 11:03
I have eliminated most of the sticky plastic issues with Table Saw "slick surface" coating. It's called DRY COAT and has been great in helping keep the track "self clearing".
Otherwise...no issues - Like designed
Old Tue 12 August 2008, 17:55
sprayhead
sydney
Maybe if one polishes the V rails it might help as well to minimize built up?
Also I think that for one wanting to use felt wipers or something of the kind, you would need to polish the tracks or at least take off the "big" scratch marks that the grinding disk leaves. "Fresh rails" are probably too abrasive for felt wipers.
Old Tue 12 August 2008, 20:57
Sure, the smoother the rail, the less chance of that thin crust forming.
When the grind disk is set down "flat" (touching the big wide face) it leaves a very good finish. It depends on patience.
Old Wed 13 August 2008, 01:05
sprayhead
sydney
By set down "flat" you mean the whole diameter (or chord) of the disk touching the rail while grinding the 45deg chamfers?
Old Wed 13 August 2008, 01:20
Yes
Old Wed 13 August 2008, 04:26
When I ground my rails the problem I had was they became very polished before I was ready. When this happened the grinder stoped cutting away metal. I needed the "big" scratches so several times during the grinding process I dressed the wheel. The dresser needs to be the kind with the spinning washers, not the stone type , all it did was polish it more. When I had nearly finished I put one of the worn out wheels back on the grinder, readjusted the skate so the wheel made 100% contact with the rail (like Gerald said) and polished the rails to almost a mirror finish.
I think the felt wipers will be the answer to any dust buildup, although for me it is not a major problem. I currently wipe my rails down with an oily rag about once a week. The oil seems to just breakup the thin black buildup as the rollers continue to roll back and forth. My plan is to make the felt wipers in such a way as to create a guard for the rollers. I'm considering a round piece of felt with the end cut to a v then put in a small metal pipe, spring loaded to the rail with a small hole in the top for an occasional drop of oil).
Old Thu 14 August 2008, 03:48
sprayhead
sydney
J.R. your idea sounds great, and thanks for the ideas.
Gerald did an isometric sketch for a protection casing for the wheels and it had great looks plus a host of features. I did not find it though, it's somewhere in the deepness of this addictive forum. I'll find it and post it here.
Old Thu 14 August 2008, 03:53
It was on the previous version of this forum:
http://www.mechmate.com/Forum/messages/2/185.html
Old Thu 14 August 2008, 04:30
By looking at the date on this previous forum, it would be right to assume either MechMate user or even some other bot users don’t really have a need for those !! ?
Old Thu 14 August 2008, 22:44
sprayhead
sydney
Robert I think that there are certain application that do call for a way to keep the rails and wheels cleaner.
Old Fri 15 August 2008, 04:44
I agree with you “sprayhead ” !!
It’s just my way of actually asking to other that may have them to report if they see a real need ?
Old Sat 16 August 2008, 03:16
sprayhead
sydney
Oh,, ok, my english is not yet as I would like it to be, sometimes this kind of stuff happens.
Yep, sprayhead is a bit "how'ya going" I agree. My real name is Francis.
Old Mon 18 August 2008, 06:34
sprayhead
sydney
Guys, does the wheels ever get clogged up? Ever had to scrape/wipe the wheels?
thanks
Old Mon 18 August 2008, 22:21
So far no problem, even before I had dust extraction it stayed clean.
Old Tue 19 August 2008, 06:20
No problems here.
