Old Fri 08 July 2011, 15:19
decibel
Just call me: Doug
Auckland
New Zealand
Cheap VSD?
Hi all,
A bit vague, but a local auction site has a new Toshiba VFS11S 2.2kW 230V 1ph to 3ph.
While I haven't decided on router v spindle yet, this might seem like a cheap way into the spindle drive.
Question is, will this drive the 2.2kw Chinese spindle that many seem to be using, or do I need a little headroom.
My workshop power supply is single phase 230v.
As I said a bit vague but I can't pass up a bargain.
Cheers,
Doug
Old Fri 08 July 2011, 17:17
Yes, that appears to be a good match to a 2.2kw spindle. There is no need to oversize a VFD if you are within its normal specifications.
Old Sat 09 July 2011, 03:35
You will have no problem with that VFD, they are designed to give the rated current. Only thing you need to look is if it will supply the needed 400Hz for the high frequency spindle (24.000 rpm) or 300Hz for 18.000rpm.
and as I see in datasheet it says
OutputFrequencyRange 0.5-500Hz (default 0.5-80Hz,MaximumFrequency30-500Hz)
so it should be ok.
Old Sat 09 July 2011, 03:53
Make sure you specify the working voltage of the spindle when you place your order.
DriverMotor Motors and Controllers in Cabinet (SOLD!) guerd87 Archives 8 Tue 11 October 2011 03:06
A cheap USB gamepad that controls all Mach3 functions Atifeh 80. Computer Hardware & Software 1 Mon 14 February 2011 05:43
Motion King 34HS6803-G5 and G10 cheap gearboxed steppers hutchcj Motors & their mountings 6 Mon 11 October 2010 23:07
Cheap wrapper for indexer normand blais CAM 0 Sun 24 January 2010 13:14
Cheap Control Box Radishworks 70. Control Systems 3 Fri 20 November 2009 02:20
