Old Fri 04 December 2009, 06:31
paul60
Just call me: woodguy
st george
Barbados
mach 3 setup help
on the pmdx-122 it shows the drive and step as 2-3 4-5 5-7 and 8-9
under port and pins motor output it shows just one x supply
as there is two motors should it not be two supplies?
thanks paul
Old Fri 04 December 2009, 06:37
Woodguy,
If you use one port, say J1, for both X's then you will use 2-3 for X. Many have both X motors going to the same J1.
If you use two ports, say J1 and J4, then you use X and A-Axis for the second motor and you would use 8-9 for the A-Axis and 2-3 for X.
Hope that helps
Old Fri 04 December 2009, 07:57
paul60
st george
Barbados
thanks but still not sure
i have my 4 gecko drives connected to ji j2 j3 and j4
then i should use a-axis?
if so how do i set up the a-axis?
where do i add a-axis to the motor setup page?
sorry i realy dont have a clue.
woodguy
Old Fri 04 December 2009, 08:03
paul60
st george
Barbados
thanks but still not sure.
i have my gecko drives connected to ji j2 j3 and j4 then i should use a-axis correct?
if so how to i add a extra a-axis to the motor output
and does it matter if one x axis goes to j1 and the other to j2
woodguy
Old Fri 04 December 2009, 12:47
Woodguy,
First I would suggest that you go to the Mach website and download the configuration document. It talks about how to set up the additional motor.
The A-Axis is below the Z motor and you use 9,8 for it. Also you have to set up the A-Axis in Input Signals and under Slave Axis you have to declare the drive.
Get the document, if you have any questions after you look at that, post them.
We will help you but you need to look at the document. It will save you some head aches.
Old Mon 28 December 2009, 08:10
paul60
st george
Barbados
I have setup my controller today. jog all axis, setup e stop, tune motors.
i am not trying to set up my zero plate in setting alt6 i have added zero plate thickness,
and safe z height. i used port 1 pin 11 and enabled it as low active.
what i am not sure about is where do i wire the z plate to the controller.
[on another subject] if i shutdown my computer before i shutdown the controller
i get a loud thump and the x axis lurch forward about 1/2 inch.
definitely a problem there.
thanks paul
i have added a zero z scrip with 5 sec delay on a dro on mach3 controll screen . did this with the help of
Scott Worden .
Old Tue 03 August 2010, 10:49
renraku
Just call me: renraku
rome
Italy
Hi, do you know a complete mach3 setup for mechmate, 4 stepper motor (2 on X axis ) pmdx-122 - gecko g203v, i just know how many step motor needs for 1millimeter move
Could you tell me step by step ( if simply procedure ) mach3 page setup ? thanks
Old Tue 03 August 2010, 11:02
Renraku,
There are some excellent documents on the Mach website that will help you on how to set things up. That is a very good place to start because you will learn other things that will be most helpful to you.
Try there first.
Setup document "Mach3 CNC Controller - Software Installation & Configuration" Gerald D CNC motion control software 4 Fri 08 January 2010 10:34
Table Design for twin spindle setup Travish General - MM Build 7 Fri 09 October 2009 19:08
Looking For help to setup my CNC Router - to visit in Northern California Mcyoda Construction started, but not cutting yet 0 Sun 27 July 2008 18:45
Cannot get motor to turn - Mach Ports & Pins setup kalimero Troubleshooting 18 Tue 06 May 2008 09:50
Upgraded Mach, now the motors won't turn - Different ports/pins for later Mach Hugo Carradini Troubleshooting 19 Thu 25 October 2007 11:45
