Old Wed 17 January 2018, 08:04
YANLM
Just call me: Yannick #129
ST DENIS
Reunion
Making Cuts #129 - St Denis, Reunion
Hello.
A report of my project with a modification of the skate.
Old Wed 17 January 2018, 12:56
Borko
Just call me: Techstarve
Veles
Macedonia
Welcome aboard. It seems to be nice weather out there in this time of year.
Old Wed 17 January 2018, 13:26
YANLM
ST DENIS
Reunion
The time is beautiful but a cyclone (named BERGUITTA) threatens us at the moment.
Old Thu 18 January 2018, 09:50
Welcome aboard!
Old Fri 19 January 2018, 05:15
Yannick,
I see you've been around about 5 years. Congratulations on your decision to build a MechMate and on your progress so far.
Regarding the skate. Do I see bolt ends at the far left and far right of the photo? When I used a similarly designed skate, the bolts that rode the top of the rail "wore" to the point that my depth of cut was affected. Thus the grinding wheel became more aggressive on subsequent passes. After noticing this, I found that I had to keep adjusting the bolts as they wore.
To remedy this, later designs of the skate placed bearings where you have bolts so the bearings could ride the top of the rail. The bearings don't wear as you make your passes resulting in better control of the depth of cut.
Old Fri 19 January 2018, 21:07
YANLM
ST DENIS
Reunion
john,
you are right. the bolts affect the top of the rail but as I finished the rails.
I did not notice or forget that the skateboard was planned for 115mm and not for the 125mm discs.
Old Fri 19 January 2018, 21:22
YANLM
ST DENIS
Reunion
Hello.
Old Sat 20 January 2018, 05:05
Well good. That's a tough job COMPLETE! I hope you're happy with the results.
Thanks for sharing more progress photos.
Old Mon 22 January 2018, 08:00
YANLM
ST DENIS
Reunion
10.40.364 steel tubing replacement
hello. can i replace this part 10.40.364 (50x25x3 steel tubing) by this 60x30x3 without problems. when i look the plan it seem possible. but i'm not sure about the screws or something else.
Old Mon 22 January 2018, 08:09
YANLM
ST DENIS
Reunion
Sous le soleil de l'île de la Réunion / Under the sun of the Reunion Island
a link to discover "the ultimate island"
(It is not from me it is the tourist office)
https://en.reunion.fr/
Old Mon 22 January 2018, 08:20
YANLM
ST DENIS
Reunion
Hello
Gantry
Old Mon 22 January 2018, 12:37
Borko
Veles
Macedonia
What a exotic place. I discovered it through our forum.
Yannick, you are doing good progress.
Old Wed 24 January 2018, 06:05
Progress looking great. Glad to see build posts!!
Old Sat 27 January 2018, 09:25
..."Glad to see build posts"...ici aussi
Old Sun 04 February 2018, 07:30
YANLM
ST DENIS
Reunion
Hello, photo of the construction. I am going to begin the electric part soon
Old Mon 05 February 2018, 10:40
YANLM
ST DENIS
Reunion
it's not easy but with a bit of patience.
Old Tue 06 February 2018, 04:31
Looking great! Like the progress.
Old Mon 12 February 2018, 11:08
YANLM
ST DENIS
Reunion
some progress
Old Tue 13 February 2018, 04:30
Looking good!
Old Tue 13 February 2018, 09:38
YANLM
ST DENIS
Reunion
Soon the cabling
Old Sat 03 March 2018, 06:09
IamDave
Just call me: Davey
Ball Ground, GA
I just stopped by to check on you, Yannick. I am hoping good progress for you.
Old Sat 03 March 2018, 09:10
YANLM
ST DENIS
Reunion
I moved forward on the construction. All the axes work. But at the moment I have difficulty with mach3.
https://youtu.be/xxWOjvbM7t8
Old Sat 03 March 2018, 12:12
IamDave
Just call me: Davey
Ball Ground, GA
If you post a little bit of problem, I help search on here for a solution. "Lots of really talented people, have posted good information. It is just hard to find."
Old Tue 06 March 2018, 18:59
YANLM
ST DENIS
Reunion
wiring
the wiring is almost complete.
Old Wed 07 March 2018, 10:45
YANLM
ST DENIS
Reunion
wiring complete
estop and push button too
but I am completely blocked by the spindle which does not start with mach3. Anybody would have a vfd Fuling ?
Old Wed 07 March 2018, 10:51
YANLM
ST DENIS
Reunion
The construction in image
Old Thu 08 March 2018, 07:19
IamDave
Just call me: Davey
Ball Ground, GA
Is this the one you have, Yannick? https://www.youtube.com/watch?v=wgZ1dijgvuU
Old Thu 08 March 2018, 08:11
YANLM
ST DENIS
Reunion
hello Davey, i have seen this video before. It's not the same model but the parameters seems to be the same when i compare with the user manual of my model (downloaded because the user manual delivered with the vfd is in chinese).
In manual mode it work very well.
Old Fri 09 March 2018, 07:22
ifffff
Just call me: Ivo #38 & #130
Parnu
Estonia
Did you switched parameters from inverter menu to change command source?
P0.01 from 0 to 1 keyboard to terminal control
P 0.03 from 0 to 1 to control ferquency instead keyboard 0-10v source
https://www.manualslib.com/manual/82...page=21#manual pages 20-21
Old Fri 09 March 2018, 08:14
YANLM
ST DENIS
Reunion
hello Ivo
Yes i have changed the command source.
i see variation on the vfd screen, when i jog 0-10v with the breakout board software. i found 24v between S1 and DCM and variation when i measure between VI and ACM .
I found 24 V between S1 and DCM when i activate the relay but i also found 24v when the relay is not select !!
and ACM and DCM are connected to 0V on my bob (all 0V on Bob are connected).
More progress, it cuts ! #109 - Hampshire, UK Andrew_standen MechMates already cutting 75 Thu 23 July 2020 13:23
First Cuts And Has Stickers! #126 - Genesee, WI hflwaterski MechMates already cutting 215 Tue 11 April 2017 12:00
First Cuts #108 - Willemstad,Netherlands parrulho MechMates already cutting 154 Sat 15 November 2014 12:14
Making First Cuts #56 - Empangeni S. Africa Lex MechMates already cutting 263 Tue 30 October 2012 23:14
My first cuts bbreaker The Show Room 2 Sun 22 June 2008 23:06
