Old Sun 23 May 2010, 04:11
hutchcj
Just call me: Colin
Sydney
Spider plate - 194mm wide and 4mm thick
I've got the laser cut parts for my MechMate and I had a quick look at the spider plate. It's only 194mm wide (should be between 199 and 196mm) and only 4mm thick (should be 5mm). Other than needing large spacers to bridge the 6mm gap to the Y Car, is there an issue with the width and/or the 4mm thickness.
I'll check the rest of the part for tollerence tomorrow.
Old Sun 23 May 2010, 04:16
AuS MaDDoG
Just call me: Tony #71
Brisbane
Hi Colin,
Should not be too much of a problem, just use spacers between the spider and the car and all should be good.
Tony.
Old Sun 23 May 2010, 04:20
hutchcj
Just call me: Colin
Sydney
What about the thickness of 4mm. I was thinking that Gerald originally made it 5mm for a reason. I don't really like the sound of the spider breaking mid cut.
Old Sun 23 May 2010, 04:25
AuS MaDDoG
Brisbane
Colin,
5mm is the prefered check out this thread, http://www.mechmate.com/forums/showthread.php?t=1043
Tony.
Old Sun 23 May 2010, 04:40
rotorzoomer
Just call me: Account - DISABLED
Account - DISABLED
Grrrr
Mine is 4mm thick too
Will need to contact supplier about this; especially being for such a integral part to the build process to be under specification.
Old Sun 23 May 2010, 05:47
Are you measuring the thickness of the plates with a digital Micrometer?
Any photos? Where are you measuring the thickness?
Does anyone know the tolerance swing on metric plate material thickness?
Let's see some pictures of these spider plates.
Old Sun 23 May 2010, 06:01
rotorzoomer
Account - DISABLED
Spider Thickness
The spider thickness on my batch are 4mm all round measured on all corners, sides, insides e.t.c. It's obvious that it's 4mm material no matter where you measure it.
See pix below...
Old Sun 23 May 2010, 06:02
hutchcj
Just call me: Colin
Sydney
I haven't measured the thickness with a micrometer yet but I can do that tomorrow. But really I don't see how this is a factor. 1mm is easy to see, even without a ruler.
No photos yet, as I don't have the parts with me. But I could probably upload some tomorrow if you like.
Again, I don't see why it matters where I take a measurement for thickness? If the sheet is 4mm, then it's 4mm all over (except for maybe the bends).
Old Sun 23 May 2010, 06:04
Yeah I meant not at the bends. It is an easy spot to measure, but just making sure not to measure there.
Old Sun 23 May 2010, 09:22
The plates were originally 4mm thick. Quite a few builders commented on flex issues. I personally did not experience flex, and the builders who commented on flex were asked to measure the flex with a dial gauge. Despite no measured flex values being forthcoming, I decided to err on the side of caution and increase the spider thickness from 4 to 5 mm. That revision was also made to prevent the inch guys from choosing 1/8" inch instead of 3/16".
Old Sun 23 May 2010, 11:01
My spider plate was cut out of 3 mm steel by accident and up to now had no headaches and I use my MM everyday ( watch my space on Tuesday).
Old Mon 24 May 2010, 09:44
MM #5 had a 3mm steel plate spider and has worked perfectly for years now. That spider is now found a new home on MM #58 as the second z-slide for the MechTorch table at UNCSA. I never noticed any challenges when using the spider. Notably, I had the short stroke slide on #5 with Pre-Mamba parts.
Spider Plate Oh-Oh!! (which # mark to drill on?) SteveE 40. Z-Slide 12 Tue 01 March 2011 08:20
Spider Plate Too Wide? anton 40. Z-Slide 2 Mon 23 November 2009 05:09
Is the MM the right machine for Me? (cutting thin boards and thick foam) 1foamimprovement General - MM Build 5 Wed 18 February 2009 18:24
Check "Spider Plate" 10 40 432 for flatness dmoore 40. Z-Slide 1 Fri 16 May 2008 22:13
Extended Z-axis vibrates - stiffening spider plate Art Archives 21 Mon 14 April 2008 12:59
