Old Fri 09 March 2012, 18:06
barry99705
Just call me: Barry
Xenia
Originally Posted by darren salyer View Post
Thanks...I think....
Heres how it looks today with a 61"x145" MDF spoilboard
Just painted it yesterday.
Hope to get some re-assembly done this weekend..
Hey look! His garage door is still white!
Old Fri 09 March 2012, 22:42
Nice. I see you used the spoilboard as a buffer between the MM and the garage door
Old Sat 10 March 2012, 06:07
Actually, the car dollys are still under the rear legs, I used a floor jack to move it to the center of my shop and put 25'x30' of plastic on the floor under the table, and sprayed it there, then moved it back after it dried.
Cleanup consisted of rolling up the plastic and throwing it away.
Its next move will be into a dedicated room in the back of my shop...
And in the spirit of the founder......someone really needs to empty that dust collector.
Old Tue 13 March 2012, 17:21
another couple bites of the elephant....
Old Tue 13 March 2012, 19:55
I have (4) NPN NO proximity sensors, and in reading through the threads related to them, it seems I need to supply them with 12 volts to use them to switch a relay that will then provide 5 volts to pin 15 of the PMDX.
Over simplified, I know, but i'm looking for a shopping list.
Sooo, 4 DIN mounted relays with 12 volt coils, and a power supply with a 12v and 5v tap should be on my want list.
Correct?
Old Tue 13 March 2012, 20:23
Mostly correct.
You can see what has been earlier on this post:
http://www.mechmate.com/forums/showt...4&postcount=59
Your switching a "dry contact" to the pin on your break out board that just happens to be wired in series for the homing sequence in Mach. My drawing shows a couple things that have been changed.
I am supplying only 12VDC to the prox circuit and the DIN mounted relays. The proximity sensor(s) are always active and "sense" the hole in the rail or a de-rail situation to shut down the system.
If you have any really needy questions, send me a PM.
Old Tue 13 March 2012, 20:35
I read that entire thread, And I'm pretty sure I understand whats going on.
I'm putting together an order to Factorymation, and the DIN relay you spec'd is of course obsolete now.
Any special 12volt coil relay requirements I should be aware of?
Good to know that 12v to the BOB isn't a problem.
Old Tue 13 March 2012, 20:47
TechGladiator
Just call me: Miguel #94
Randolph, NJ
Hey Darren;
If you plan to put lights on the door that show the status of the prox I would recommend the DPTP Relay (Double Pole, Double Throw) http://www.factorymation.com/s.nl/it.A/id.105404/.f
if not, you can just go with the SPDT (Single Pole, Double Throw) http://www.factorymation.com/s.nl/it.A/id.105420/.f
Those are what I have on my built and they work great. If you need any help with the wiring let me know.
Miguel
Old Tue 13 March 2012, 21:03
Thanks Miguel.
What are the 5 red and 5 green lights on your door for?
I'm assuming for the proxys, but can you enlighten me a little on how they are set up?
Green when all is OK, red when they are sensing a hole or derail?
And why 5?
Thanks.
Old Tue 13 March 2012, 21:24
TechGladiator
Randolph, NJ
@Darren: I use 4 Green when Each of the proxys is "OK", 4 Red when not "OK", 1 Green when Spindle is running and 1 Red when E-Stop is engaged.
Old Thu 15 March 2012, 08:23
Still have the relays at Factorymation:
http://www.factorymation.com/s.nl/sc...gory.259183/.f
Old Fri 16 March 2012, 16:47
I know I'm not the first, but here is my Central Machinery dust collector modded with a Thein baffle and a Wynn filter.
If I'm the first with a MechMate branded collector, I'd like to apply for serial #1.
I have the blue paint and the logo, and i'd be happy to post a video of it sucking up dust, if necessary......
See what happens when i'm given too much free time in the evenings?
Old Fri 16 March 2012, 17:31
That is a first
Old Fri 16 March 2012, 19:17
Hmmmm - may need to add that to the catalog offerings !!!
Old Fri 16 March 2012, 22:34
Must be a PROUD MechMate owner....nice
Old Sat 17 March 2012, 10:34
WTI
Just call me: James
Detroit (Michigan)
Hah! Love it!
Old Sat 17 March 2012, 16:47
Axel1966
Just call me: Axel
Paris
France
So cool !
Old Wed 04 April 2012, 19:02
OK,
Not much posting but a lot of behind the scenes research.
Control box and wiring stuff arrived from Metalhead today. (Thanks Mike.)
For motors, I'll be using KL34H280-45-8A
For power supply i'll be using a 5N48R12
I have 4:1 belt reductions
I believe I'd be best suited with 25 tooth pinion gears, but any advice would be appreciated.
Old Wed 11 April 2012, 08:40
Well, motors and power supply are here.
Still researching the 25 tooth pinion question.
About to order the 4 G203v, pmdx-126, pmdx-134, and an Ethernet Smoothstepper.
I'm hoping to be able to lay out the control box so 6 inch ribbon cables will work.
Old Sat 21 April 2012, 11:28
I've strung the 4 core cables to the motors, and I have a question on the 8 core to the pushbutton boxes.
Are these wired in series IE: Y car box to far gantry box to near gantry box to control box?
Seems logical to do it this way, but...
I'm confusing myself the more I research.
Old Sat 21 April 2012, 12:19
Darren,
The E-STOP are wired in series, the Momentary push buttons (start and feed hold) are parallel.
Old Tue 29 May 2012, 19:00
Control box is coming along.
Here is a pic taken before the final connnections to the machine itself.
I've had it moving under its own power using the test mode built into the BOB.
A few more hours and it will be fully functional.
I'll probably have some Ethernet Smoothstepper questions to ask.
Old Fri 01 June 2012, 00:03
Red_boards
Just call me: Red #91
Hi Darren,
Neat job.
From this angle it looks as though it will be hard to plug the parallel cable into the BOB?
Old Fri 01 June 2012, 00:22
Axel1966
Just call me: Axel
Paris
France
Hi,
Maybe the breakout board may has been lifted up ?
Old Fri 01 June 2012, 05:01
He will be using the Smooth Stepper so no parallel cable will be used.
Old Fri 01 June 2012, 06:19
Neat!
Old Fri 01 June 2012, 06:46
Thanks everyone.
Wiring is definitely not my strong point, and its been a challenge to make it neat and tidy.
I will say this to anyone contemplating a build:
Don't let fear of a portion of the project keep you away. It will get figured out as you progress.
Also, documenting your build and posting pictures along the way will force you to build to a higher level of quality, knowing its going to be seen by some very accomplished builders.
Mike is right, the Smoothstepper eliminates the parallel cable and its connection.
Now if I could only find the few hours needed to finish it up.
12 hour days at work for the next few weeks trying to catch up on a backlog of work.
Old Sun 03 June 2012, 05:16
Hi Darren
It is some time ago but you mentioned using NPN proximity sensors.
As you are using the PMDX 126 breakout board you can connect them directly to the board itself. Nothing other than the wiring of the 4 sensors together to run back to the PMDX 126 is required.
Page 22 of the latest manual has the wiring diagram you require.
Also I see the Ethernet Smoothstepper in place in the control box, mine runs very well indeed. Keep up the good work you will soon have your machine moving.
Old Mon 04 June 2012, 07:07
Thank you, Ross.
I'm getting very excited now that I'm getting closer.
Can I power the ESS from pin 26 of the ribbon cable connecting to the BOB?
Documentation on the ESS is VERY lacking.
I'm assuming one ribbon cable connecting port 1 of the BOB to port one of the ESS as well.
Old Mon 04 June 2012, 07:36
Hi Darren
I power everything inside the control box from 5V and 12V taps in the torriod power supply so have have no experience with using pin 26 as the power supply.
The ESS uses 5V as you say, it might also be beneficial if the ESS is always powered up when the PC is on as Mach3 expects the ESS to be powered up before it starts.
University Of Missouri Saint Louis Theater ganderson Introduce yourself and start planning 8 Fri 31 October 2014 17:53
Starting my MM Build - St Louis MO USA inventek2000 Construction started, but not cutting yet 38 Sun 25 September 2011 17:51
my machine cnc marcoscnc29 Archives 1 Sat 24 April 2010 17:58
