Thread Tools |
#31
I have the 72 count larger pulleys so an 18 or a 24 would work.
Armando |
#32
Armando your 14mm ID, 18t pulleys are done. PM me a address
Jason |
#33
Armamdo you may need different belts if you had a 24t setup sent to you.
Jason |
#34
Looks like the difference between a 24t x 72t(100 teeth and 4.962",3:1) and a 18t x 72t(98 teeth 5.0019",4:1) is 2 teeth and .038 of a inch, to be 5 inches part.
Jason |
#35
The setup I had originally was the 18x72 (4:1) so I should be ok.
Armando |
#36
Jason,
I received the pulleys you machined for me and are way way better than the the ones I screwed up on the drill press. I can now move forward with the transmissions. Thanks alot for your help. Armando |
#37
No problem. I just speed reamed them on the lathe. I have time issues. If you need a high tolerance let me know.
Jason |
Thread Tools | |
pinion gearing and difference in sizes | Gabriel | Rails & Rollers | 4 | Wed 18 May 2011 14:19 |
Spur Gears where I can get them besides mcmaster? | kanankeban | Driving Mechanisms: Rack/pinion, gears, screws, belts & chains | 8 | Tue 29 June 2010 17:34 |
Spur Gear decision | shelbygt500buddy | Driving Mechanisms: Rack/pinion, gears, screws, belts & chains | 2 | Wed 14 April 2010 05:46 |
Cable amp wire sizes | Gerald_D | Golden Resources | 3 | Sun 14 December 2008 23:17 |
Steel sizes | Gerald_D | Golden Resources | 2 | Fri 05 December 2008 12:25 |
