Old Wed 30 May 2018, 11:33
kourch
Just call me: Morad
Casablanca
Morocco
Is the Main longitudinal beam Taper Flange or Parallel Flange Channel
Hello,
I would like to know if the main longitunal beam taper flange or parallel flange ?
Thanks.
Old Fri 01 June 2018, 04:48
Admin
Alabama
It can really be whatever is available to you as long as it is rigid. Most used a taper flange.
Old Fri 01 June 2018, 22:01
kourch
Just call me: Morad
Casablanca
Morocco
Thank you Mike, i purshase once with taper flange
Old Sun 03 June 2018, 10:46
Taper is technically stronger if the sizes are the same however it adds other items to deal with if you choose to bolt through using a bolt and nut. If you choose to tap the hole it is not an issue, if you don't I recommend using wedge washers as they are made to keep the nut parallel to the surface tension that it applies. I used tapered flange C-channel as well.
Longitudinal beam options for 350mm Z-axis Red_boards 10. Base Table 8 Mon 22 November 2010 06:38
Problem with Main Longitudinal Beam gixi 10. Base Table 32 Thu 19 November 2009 14:23
Main Beam - Structural Channel vs Ship Channel jehayes 10. Base Table 2 Thu 09 July 2009 20:40
Power supply for the PMDX-122 Parallel breakout board - 9V AC from main transformer bradyaero 702. Power Supplies 14 Mon 01 December 2008 15:00
Location and spacing of X rack from main beam? dmoore Driving Mechanisms: Rack/pinion, gears, screws, belts & chains 3 Sat 26 April 2008 23:44
