Old Wed 15 August 2018, 18:42
I do not have an RS 484 port.
Attaches is a picture of the board that I have.
Will this work with the inverter?
Old Wed 15 August 2018, 19:01
Looks like it will work, it should be a bit tricky.
On the inputs, I've generally wired to the first and third. Make sure you're over-rated on the inputs by 2/3.
On the spindle output, you definitely should not try any form of switching between the VFD and spindle. That would break things in ugly ways.
You mentioned that you might want to place a relay there. You would place the relay so that it controlled the forward speed selector on the input to the VFD.
Looking at that board, and at https://www.manualslib.com/manual/12...page=12#manual it appears that there is a 0-10V output to control the speed. That would be wired to the corresponding input on the VFD.
Old Wed 15 August 2018, 21:26
You only need a serial to rs485 converter then run a serial cable from PC to the converter and the converter to the 485 on the vfd
Old Wed 15 August 2018, 23:05
Thank you Paul.
I will look into that.
About the earthing.
I have an earth from the machine frame to a spike in the garden.
Can I earth the VFD to the frame or should I run out a separate earth wire?
Old Thu 16 August 2018, 04:26
Straight to earth ground only needed if you experience EMI interference.
Old Sat 18 August 2018, 03:41
I got power to the VFD.
Parameters set.
Coolant pump and tank installed and working.
Probably Monday for VFD to spindle.
The fog is slowly clearing
RS485 on order.
Old Sat 18 August 2018, 05:05
Al,
Sounds good. Thanks for sharing your new venture.
Old Mon 20 August 2018, 05:10
VFD and spindle wired and rotating.
Onward to the next job
Old Mon 20 August 2018, 05:51
Awesome
Old Fri 24 August 2018, 23:21
Bracket modified, drilled, tapped and painted.
Z slide drilled and painted. (Yellow, sorry)
Spindle mounted.
Cable and pipes routed through energy chain.
More to do yet.
Old Sat 01 September 2018, 02:23
Well it works.
Under manual speed until the RS adapter arrives.
Still a few wires to tidy up.
Glad that job is done.
Taken a few years to get there.
Lots of information in the instruction manual but hard to understand.
It doesn't tell you how to do things, just information.
Machined some wood to thickness, will run a job tomorrow.
I would like to get Pathpilot to run but I am stuck on the pin settings.
It keeps rejecting mine.
One job at a time.
Old Mon 03 September 2018, 05:13
Nice!
Sorry, I have no experience with Pathpilot.
Old Tue 11 September 2018, 23:46
I have a problem that I need some help with.
It might be electrical noise.
Sometimes when the spindle starts or stops the Yaxis jumps.
More often it is when it stops (the very last 1/10 second).
On occasion the spindle will growl on start up
The X and Z are fine.
I put in a separate earth on the VFD, also it is on a separate circuit breaker.
The separate circuit helped but it is still not right.
I don't know what to try next.
Any ideas ?
Old Wed 12 September 2018, 09:53
digger
Just call me: Milosh #113
Toronto
Make sure you have RF chokes installed at the output of the VFD. VFDs are big source of RF interference. I removed RF chokes/toroid cores from some old scrap monitors. You will see them as a thick piece of plastic over the monitor supply cable or connection cable. Remove them from there and slide your wires (the one which go to the spindle). If there is a room you can winde a few turns as well. Install it at the VFD side. This should prevent RFI.
Milosh
Old Thu 13 September 2018, 00:06
Thanks Digger.
I found 3 of different sizes on old cables.
Put one on each of the VFD output wires.
It made no difference.
Will have to see if I can find bigger chokes.
Perhaps more than one per cable is needed.
Old Thu 13 September 2018, 05:56
digger
Toronto
If the hole is big enough, try to run some turns. More turns, more inductance. Also, it may help if you try to physically separate spindle cable from other cables.
Old Sat 15 September 2018, 02:55
Thanks again Digger.
I removed the spindle cable from the energy chain.
Now it works
Old Sat 15 September 2018, 06:29
digger
Toronto
No problem. Glad it worked.
Old Sat 15 September 2018, 07:47
racedirector
Just call me: Bruce #122
New South Wales
What sort of cable are you using for your VFD to spindle? I run mine in my chain with everything else and have never had a problem. My cable is shielded VFD cable.
Old Sat 15 September 2018, 08:08
digger
Toronto
It is shielded and shield is grounded at vfd side.
Old Sun 16 September 2018, 16:47
That sounds to me like you are getting spindle noise transferred into your Y axis motor cable. If it were transferring to your limit switches, you should see that in the software effect. It might be as simple as keeping the spindle cable to one side of the echain, and the other cables to the other - a few zip ties.
Old Sun 16 September 2018, 19:21
The problem was that the spindle cable was not properly shielded.
Now that I have separated it from the others it works.
It will do until I can find some proper cable.
Very difficult to find around here.
The RS adapter has arrived, so more wires to play with.
Old Mon 17 September 2018, 03:49
racedirector
New South Wales
Heres where I got mine from, been brilliant and no interference at all. It runs in my chain with everything else. Very cost effective too....
https://www.homanndesigns.com/index....r0u074a976a7b3
Old Sun 30 September 2018, 22:50
Thanks Bruce.
I have emailed them.
Is the shield attached to the spindle body
and the earth on the VFD?
Old Sun 30 September 2018, 23:48
racedirector
New South Wales
Hi Al
I'll check today what I did, been getting Pathpilot 2 talking to my Mesa cards today, they decide to ignore each other!
Will report back shortly
Old Sat 09 March 2019, 18:09
There is a divorce in progress.
I made this as the lyrics sum up my mood.
It is by The Who, titled "It's not enough".
It hits the nail on the head.
The film mentioned was released under an English name.
"Contempt"
Very apt.
Old Sun 04 August 2019, 05:27
When I was cleaning my machine today,
I noticed something.
A mistake in construction.
3 of the 4 angle stays on my Y axis were welded with the inside angle upwards.
A major dust trap.
Oh well!
MechMate, Always a surprise, never a disappointment.
Old Sun 04 August 2019, 09:17
Make a cap for them out of sheetmetal, plastic or cardboard
Old Mon 05 August 2019, 05:34
Thanks for the suggestion Mike.
It will have to wait.
I need to get out of here next year.
The machine will be moved.
The big problem is the base.
It cannot be moved intact from where it is now.
Either I leave it and make a new one. or cut off the 4 X axis beams and make new ones.
Always something to think about
Old Mon 17 May 2021, 01:02
Hello all.
It has been a while since I was last on here.
The last 4 years have been hard.
I had to disassemble my machine and move to a new location.
I have a few problems that I could use some advice on
The machine cuts out shortly after starting.
I feel that it is a computer problem, it must be 20 years old.
Parallel port and all that old technology.
I am thinking of using a Raspberry pi with Linux.
Any ideas about what I would need?
Control board, drives
I read somewhere about Acorn Clearpath and Leadshine self tuning motors.
Hopefully I will have some spare funds in a couple of months.
Any advice welcome.
Started making windows with the mechmate ... #70 - Rome, Italy silverdog MechMates already cutting 100 Wed 26 April 2017 22:02
Lookin for Gremlins - Isarn, TH lonestaral Troubleshooting 8 Mon 02 November 2015 12:10
Oh Can I ?? - Phuket Thailand jek Introduce yourself and start planning 10 Fri 24 June 2011 05:55
Newbie to CNC - Chiangmai Thailand chainarin2553 Introduce yourself and start planning 1 Wed 15 June 2011 05:27
Free Cad and Cam HeekCNC Windows & Linux Regnar CAM 0 Thu 16 September 2010 19:24
