Old Wed 30 November 2011, 15:52
oliver2257
Just call me: Stephen
Redwood City, CA
Checking continuity of wiring with Antec Power Supply Connected
I am hoping to power up my project without having smoke and sparks and did a continuity test with a very good True RMS Multimeter. I was hearing what appeared to be a short between my L1 and L2 hot legs, (230 V AC), lots of beeps at the wrong time. This resulted in lots of reworking, checking and wondering what was wrong. It all looked good. I wired the power supply for 230 V as per the instructions which in fact are correct. The 1st and 4th wires, red and black, are L1 and L2, with no continuity. The other pair of red/black are joined together and will also show no continuity until connected. Once they are joined then there is the issue. A few phone calls and a lot of help, just using a multimeter beep signal is not adequate to test with the power supply connected, not enough impedance in the PS. It is preferable and easiest to disconnect the PS from the system to test.
Wiring the PK296A2A-SG7.2 motors & power supply voltage selection Richards Motors & their mountings 97 Fri 29 July 2011 10:46
General wiring, supply voltages, relays, E-stop considerations jhiggins7 70. Control Systems 24 Sat 13 March 2010 02:01
The Power Supply needs only to supply 2/3 of the rated motor current Gerald D 702. Power Supplies 0 Sat 05 December 2009 20:09
Mains power wiring Gerald D 70. Control Systems 50 Thu 21 February 2008 13:00
Mains power wiring for discussion Gerald_D Archives 94 Sat 07 July 2007 08:36
