Old Sat 03 March 2018, 12:26
ifffff
Just call me: Ivo #38 & #130
Parnu
Estonia
Havent done not much meanwhile. Z axis is projected and details milled out. Made it from 15mm thick 6082 alu sheet with 50x20 reinforcements to minimize deflection.
And other free time what i have after dayjob, is gone for building complete new dust extraction system with one big central unit instead of small blower on each maschine.
More about it and more pictures tomorrow.
Old Sun 04 March 2018, 09:26
ifffff
Parnu
Estonia
As promised some more about new dust extraction system. As i earlier posted here idea is to vent that air what is coming trough dust extractor filter outside. For that i ordered special bags made from pvc tarpaulin material. Those bags are over dust filter bags and have output for air what is vented outside. Outputs are behind bags, trough wall and not visible on picture.
Now i have clean workshop air .No extra fine particle dust on air.
Blower is Holzmann ABS 5340P. It has 5hp (3,7kw) motor. It has huge suction power, and already on first tests was clear, that this is way too much. I installed for blower fan speed regulating VFD (Invertek Optidrive E3). On blower fan speed 1800 rpm it has enough suction power to serve 1-2 125mm pipes together (main pipe is 250mm).
That blower running on 1800 rpm is unbeliavably quiet. When smaller units are screaming on high rpm, then its working sound is comparable with cordless drill.
Shortage is, that on colder days is workshop colder due air exchange and needs more heating power, especially when dust blower is running long hours. But spring is around corner and that isnt problem anymore
Old Sun 04 March 2018, 09:35
IamDave
Just call me: Davey
Ball Ground, GA
System to keep the lungs free of dust. Very good idea. I wear the little white masks, when I am cutting and sanding. It is amazing how dirty they get. Thank you for the posting of pictures. You guys are inspiring to me.
Old Sun 04 March 2018, 12:16
ifffff
Parnu
Estonia
I suggest to buy instead of those scrappy white masks 3M half facemask. Example: https://www.pksafety.com/halfacres60s.html or https://www.pksafety.com/3m-7500-lea...tor-combo.html and fine dust filters https://www.pksafety.com/3m-p95-filter.html for them.
Dont buy it over internet. Go to store and find put what size / mask fits perfectly with your face. I have both of them what i linked, but 7500 series fits better to my face.
They wont leak between face and mask like those white masks, and end of dusty workday there is huge difference how much dust have you on your lungs. Of course those white ones are better then nothing, but..... they are quite poor.
Old Wed 07 March 2018, 11:31
ifffff
Parnu
Estonia
Some of Z axis details are screwed together, i hope to finish it tomorrow.
And started to install electronic and wiring
Old Thu 08 March 2018, 11:14
ifffff
Parnu
Estonia
Completed today Z axis. Flex buy pressure applyed one hand, measured on spindle bracket is about 0,08mm. To comparision, applying same force on #38 z axis i can bend it almost 1mm.
More pictures about it:
Old Fri 09 March 2018, 17:35
IamDave
Just call me: Davey
Ball Ground, GA
Awesome job
Your z looks awesome and sturdy, good for cutting thick materials.
Today I use my new mask like you suggested. I breathe good. .
Old Fri 09 March 2018, 17:36
IamDave
Just call me: Davey
Ball Ground, GA
forgot mask pic
oops
Old Sat 10 March 2018, 21:21
jeep534
Just call me: archie
prichard, wv
wonderful job it gives me inspiration for getting on with my build
happy hunting
archie
Old Sun 11 March 2018, 05:54
Love your Z axis. Thanks for the great pictures. Is it your own design?
Old Sun 08 April 2018, 05:02
ifffff
Parnu
Estonia
Yep, my design.
Got finally most of wiring job done and it moves.
And today started assemblying spoilboard.
I having some kind of problems with those Leadshine closed loop steppers. They are making sometimes weird noises, and if i rush them drivers are getting very hot. I wrote to reseller, seems what they answer. But i hope that i did not buy for 2000 euros pile of crap instead of high end steppers.
Running on 10000mm/min
https://www.youtube.com/watch?v=ud2LOupiKAw
Running on 8000mm/min
https://www.youtube.com/watch?v=WjY_z5t57Oo
There isnt even no possibility for bad contact etc, because i did not use connectors. Wires are soldered together.
Old Sun 08 April 2018, 17:58
IamDave
Just call me: Davey
Ball Ground, GA
I hope you get the problem worked out. You have more in motors, than I do my whole build already. I watched the videos-Nice.
Old Tue 17 April 2018, 03:43
ifffff
Parnu
Estonia
Spoilboard is ready and surfaced
First test cuttings made too:
Bought from ebay tool setter for Z axis. https://www.ebay.de/itm/IP67-CNC-Aut...72.m2749.l2649 Repeatability is as promised. 0,001mm. I added this upgrade to #38 too.
Still having problemis with motors. Lowered driver current settings, as Leadshine reseller suggested, strange sounds are disapered, but now i havent any power anymore. It is able to move max 6000mm/min, higher speeds stalling problems appear. On same time drivers are coing very hot. Everything what is possible to test is tested, even took computer, smoothstepper and BOB from #38 to be sure that problems arent on input signals to drivers. Now ordered one more motor -driver set what is tested for Leadshine Germany reseller and is working. When it arrives can i go on and find out what is causing problems.
Old Fri 20 April 2018, 06:55
IamDave
Just call me: Davey
Ball Ground, GA
Ivo your work is amazing.
Old Mon 23 April 2018, 11:04
ifffff
Parnu
Estonia
Got on friday new and tested driver-motor set. With new driver everything seems to work fine.
Motors stalling due too large postition difference, it was able to move max 8000mm/min, stalling on 10000mm/min :
https://www.youtube.com/watch?v=ynruS3uWVhA
on 75% current setting extreme jerky movement, but due encoders and closed loop system there is no position loss on stop:
https://www.youtube.com/watch?v=wP7aPyxdEtQ
Installed new driver and now i am able to move axis 20000mm/ min and more without any problems:
https://www.youtube.com/watch?v=Zyxa15ml2Go
Now i am waiting what Leadshine reseller is answering.
Old Mon 23 April 2018, 18:36
IamDave
Just call me: Davey
Ball Ground, GA
Glad your getting it sorted.
Old Fri 27 April 2018, 10:56
ifffff
Parnu
Estonia
Sent drivers back to reseller. Now i am waiting their standpoint on this case.
Old Thu 17 May 2018, 14:23
ifffff
Parnu
Estonia
Got new drivers, and its running again. Now its working smooth and without any strange noises, vibrations etc.
Those 3 phase steppers are quite powerful. Tried to move axes 50000mm/min - no problem. But limited max speed to 8000mm/min. Safety first, and i am sure that running it so fast will broke something soon.
Second good thing, they havent resonance on any speeds. Cuts are on all angles perfect. I cant say that for chinese steppers/drivers what are on #38.
Also ordered stickers for number.
Old Fri 18 May 2018, 15:26
IamDave
Just call me: Davey
Ball Ground, GA
Alrighty Ivo. Anxiously waiting, to see it cutting stuff. I am watching and learning.
Old Sat 19 May 2018, 00:48
ifffff
Parnu
Estonia
And it is down again. Spindle VFD starting to give e.oc.n error messages. According to google propablly bad current sensor inside huanyang vfd.
Old Sat 19 May 2018, 04:26
ifffff
Parnu
Estonia
Checked socket and wire connections. Nothing did not seem loose but tightened everything and it is working again. Lets hope that it will be so. It may be socket what connects wire to spindle. Earlyer i had on #38 2,2kw spindle (now both have 3kw unit) and that 2.2kw original socket was problematic. I threw it away and soldered wires directly together. If problems again appear, seems that i should to it again. I hate pluggable sockets on CNC. Always they are source of problems.
Old Sat 19 May 2018, 07:43
IamDave
Just call me: Davey
Ball Ground, GA
So you think is better to not use connectors, and to solder the motor wire connections as well.
Old Sun 20 May 2018, 05:12
ifffff
Parnu
Estonia
Well... There is lot of industrial connectors what are very good. But usually those connectors what are coming with chinese stuff are problematic. At least my experience is saying so.
Old Sun 20 May 2018, 16:30
IamDave
Just call me: Davey
Ball Ground, GA
Yes. I was going to buy connectors, but have decided to go with the heat shrink but joints. They have lasted well (10 Years) on my other machine.
Old Tue 22 May 2018, 15:54
I use Amphenol connectors. I replaced the originals. I have it posted about those in Tom's thread here
Old Tue 22 May 2018, 16:42
rischoof
Just call me: Rik #92
Goirle
Cool coonectors
hello Ivo, I also replaced directly the connectors from the chinese spindle by emphanol connectors.
I used emphanol for the spindle and harting Han for the motors. on the machines build by the company I work for , we use a huge ammount of connectors. never saw anny problem wiht emphanol or harting. avoid lemo connectors...
The wires are shrinked to the pins. at home, I do soldering. once had the problem that a small soldere wire (when removing the soldering rod) makes shortcut between the pins. Now I use my glasses during soldering
You have a very nice z axis
Old Thu 24 May 2018, 07:00
IamDave
Just call me: Davey
Ball Ground, GA
Amphenol connectors. Thank you for pointing it out to me. I do really appreciate it.
Old Sat 02 June 2018, 07:22
jeep534
prichard, wv
aircraft use only crimp wire to wire connections (with proper crimping tools)
archie
Old Tue 21 August 2018, 12:17
ifffff
Parnu
Estonia
I had little debt. Missing stickers.
Milling sprockets from 7075 aluminium sheet: https://www.youtube.com/watch?v=m9hT5NXK0Ng
5mm one flute endmill
Spindle 24000rpm
Feedrate 2000mm/min
Stepover 3mm
Stepdown 0,7mm
Those are "safe" settings. It can cut aluminium long hours without breaking endmill. At #38 was safe to cut 7075 alu 2x slower due flex.
Result:
Old Tue 21 August 2018, 17:37
Nice work.
I will try aluminium when my spindle is running.
Stair Beam Machine !!! #120 - Jõgeva Estonia ilmataat MechMates already cutting 48 Tue 21 June 2016 14:28
MechMates in NE or Central Florida, Jacksonville, FL Metalsmith General - MM Build 15 Mon 28 December 2015 08:18
MechMates wanted in Saudi Arabia Nicolas The Market Place 2 Tue 13 December 2011 04:13
Hi from Estonia! v2ikekresu Introduce yourself and start planning 10 Fri 26 August 2011 09:05
Completed Mechmates Album With Serial Nos. vishnu Archives 3 Sat 25 October 2008 11:53
