Old Sun 15 January 2017, 17:10
Antonio Lima
Just call me: Antonio #128
São Paulo
Brazil
Another MM is born !!! #128 - São Paulo BR
Hello everyone!
I am from São Paulo Brazil, I work for thirteen years in the furniture industry.
Four years ago I started researching the construction of a CNC router, started building my Mechmate in January 2016, the mechanical part is already finished
and I'm getting some electronics now.
Cutting area X2600 Y1700 mm.
Old Sun 15 January 2017, 17:37
Kornerking
Just call me: Pete #127
Big Falls, Mn
Kool.
We shall watch your progress.
Old Sat 21 January 2017, 18:20
sierra347
Just call me: Armando #110
Montgomery, IL
Everything looks great, you'll be cutting in no time.
Old Sat 21 January 2017, 19:17
Wow,
Looking great !!
Old Thu 27 April 2017, 20:45
IamDave
Just call me: Davey
Ball Ground, GA
Very Nice Looking rig
Old Thu 11 May 2017, 18:24
Antonio Lima
São Paulo
Brazil
Thanks everyone!
Old Thu 11 May 2017, 18:39
Antonio Lima
São Paulo
Brazil
Finally it's time to have some fun.
Next weekend I will work hard on the project and soon I will share new photos with the assembly details.
Old Tue 01 August 2017, 18:13
Antonio Lima
São Paulo
Brazil
Good news
I finished the assembly and alignment for at least two months. The panel box is small but, everything is working.
Despite the warnings, I set up the frequency inverter inside the panel, did several tests and still had no problems.
Old Tue 01 August 2017, 18:20
Antonio Lima
São Paulo
Brazil
First cuts
Cut 54 circles Ø900x9mm MDF, are not all in the picture.
Old Tue 01 August 2017, 18:53
Antonio Lima
São Paulo
Brazil
Another test
Cutting corian®, some images about cut quality.
The cut is slightly serrated, the results are satisfactory for the cutting of wood in general. The groove in the picture is 6x3mm.
Old Tue 01 August 2017, 19:14
Antonio Lima
São Paulo
Brazil
RC motor cowl
Manufacturing a RC airplane motor cowl mold.
The video link, https://youtu.be/ae-kjlu-gVE
Thanks everyone.
Old Wed 02 August 2017, 01:58
MarkRH
Just call me: Mark
Maryland
Congrats Antonio, must be nice to see it cut the first time!
Are you using direct Drive? And mach3?
Old Wed 02 August 2017, 17:21
Antonio Lima
São Paulo
Brazil
Yes
I'm using Mach3 and direct drive.
Mach3 Version R3.041
Rack and Pinion module 1
The machine works smooth, fast and continuous. Do not stop while running the lines.
Old Wed 02 August 2017, 18:15
Antonio Lima
São Paulo
Brazil
Machine and parts configuration.
Cutting area - 2600x1700 millimeters
Rack - module 1
Pinion - module 1 (Z24 teeth)
Laser cutting and folding - http://www.blankinox.com.br/ (Osasco-São Paulo - Brazil)
Bearing RM3ZZ / W3 - Chinese
Electrical and electronic parts:
Power supply of the control box - 220v
Step Motors - Nema 34 Model (KML092-F07F) 60kg.cm, wiring in series (without reduction gears)
Drivers - Gecko G201x
Toroidal Transformer - 560VA (80V 7A)
Breakout board - CNC MACH3 USB 4 Axis 100KHz USBCNC Smooth Stepper Motion Controller (Chinese)
Spinlde - Model Tecmaf TFS.3Z3M.01 / 2200KW (3HP) ER20
Frequency Inverter - WEG CFW300
Limit switches and buttons, operate with 12V power supply
Old Thu 03 August 2017, 14:58
Congrats on your build!! You get #128 - Hope this inspires all those watchers out there to get moving a build their own MechMate !!
Old Fri 04 August 2017, 05:35
Congratulations, Antonio, on earning Serial #128. Here is the Updated Builder's Log. Please check your entry for any changes you would like to make.
Old Fri 04 August 2017, 19:39
Well done #128.
Have fun.
Old Sun 06 August 2017, 19:11
Antonio Lima
São Paulo
Brazil
Thanks Gerald, Mike for the number, John # 26 to update builders log, To Al # 114, and the other members of the best forum about router cnc in the internet. I will put the number in the machine.
Thanks so much!
Old Mon 14 May 2018, 08:08
Antonio Lima
São Paulo
Brazil
One more job with Mechmate.
Custom guitar PRS 22 frets for left-handed.
https://youtu.be/zwjS12HiXdk
Old Mon 14 May 2018, 16:46
IamDave
Just call me: Davey
Ball Ground, GA
Nice. That is awesome.
Old Wed 03 October 2018, 14:45
oficina do corten
Just call me: oficinadocorten
São Paulo
Brazil
Red face Congratulations - grande trabalho, uma inspiração!
Congrats! VERY NICE JOB, a real inspiration for us brazilian fans of the Mechmate. After this I have to restart my project.
Old Thu 04 October 2018, 03:46
racedirector
Just call me: Bruce #122
New South Wales
Congrats on 128, you should be proud of your work.
Real nice job on the guitar, one of those is on my list of things to do.
Three weeks toil, another MM is born. kevinbream Construction started, but not cutting yet 10 Mon 30 April 2012 05:31
Hello From Sao Paulo, Brazil! luizfrds Introduce yourself and start planning 13 Tue 30 June 2009 16:21
