Old Mon 04 October 2010, 21:36
DTGuitars
Just call me: David
Rogersville
Source for timing pulleys
Hey guys, I just got my MotionKing steppers in today, and was trying to find a reasonable source for pulleys to build my belt reduction. The MK motors have a 14mm shaft. I want to go either 3:1 or 4:1 on reduction (still debating). After searching for some time (all afternoon), I have struck out in finding 14mm bore timing pulleys. Any suggestions for a US source for these critters?
Old Tue 05 October 2010, 02:19
jwt
Just call me: John
Wexford
Ireland
I gave up too and ended up using 10mm i/d pulleys and resigning myself to drilling them out.
John
Old Tue 05 October 2010, 03:19
I used 15 tooth XL and bore it for 14mm shaft, my motor had a keyway so I made a passage in pulley 2.5mm for the key on the mill also. and it did not break.
It works ok.
Old Tue 05 October 2010, 06:05
Check out this site
https://sdp-si.com/eStore/
Takes some digin around but here are some numbers ( for 4:1 belt drive). They will get you started.
the 72 tooth pulley is part number A6A3-72NF03716
the 18 tooth pulley is part number A6A3-18H3716
the belt is a 200xl with Kevlar reinforcement part number A6B3-080037
Old Tue 05 October 2010, 07:39
DTGuitars
Just call me: David
Rogersville
Thanks guys, it looks like I'll follow suit and bore the hole out to fit.
Mike, I appreciate the link and part #'s. I looked on thier site yesterday, but didn't see any 14mm bores, so I didn't pursue things very deeply. I'll order these this week, and get my reductions built.
BeagleBoard- Open Source Hardware KenC 80. Computer Hardware & Software 8 Thu 08 July 2010 20:18
Desperate for a new tape source iqchallenged Golden Resources 3 Sun 21 March 2010 11:34
Toothed, Timing Belt Suppliers Victorian Signs Driving Mechanisms: Rack/pinion, gears, screws, belts & chains 5 Sun 16 August 2009 00:03
Indexer Tailstock and Headstock Source sailfl 50. Toolheads 22 Mon 12 January 2009 07:33
Timing pulleys made easy stcnc The Market Place 0 Mon 08 September 2008 15:02
