Old Wed 17 April 2013, 17:49
larosta
Just call me: Phil
California
Long Table
I am considering building a table for use in cutting large fabric panels. My question is can the MechMate design be scaled such that the table size is 96 inches (2.5 meters) wide by 50 to 60 feet (15.25 to 18.25 meters) long?
Old Wed 17 April 2013, 21:35
There has been a 20 foot table done already.
20' long table, 5HP spindle - Port Aransas, USA
Old Wed 17 April 2013, 23:18
swatkins
Just call me: Steve
Houston
Would the cables become too long at 60 feet?
Would all the cables need to be increased in size to combat signal loss and voltage drop?
Old Thu 18 April 2013, 00:03
for the stepper power cable, at 3A@60V, I don't see serious voltage drop issue. but I do worry the small signals @5V@mA signal, you can always use 12V or better still 24V small signal config.
Old Thu 18 April 2013, 11:48
skypoke
Just call me: Chuck
Port Aransas
I think the limiting factor is more the span of the gantry and what tool it will carry than the x length. I'd sure consider drives and travel speeds carefully before jumping into it. As others have mentioned, the increased cable lengths will make wiring quality and sizing more critical and the potential for noise on these longer cables is increased.
Not familiar with fabric cutting. I'm assuming a swivel head knife is used? Wonder how many lbs of down force are required? Making hot air balloons?
Chuck
Old Thu 18 April 2013, 13:44
digit
Just call me: Dominic
Quebec
4mA - 20mA current loop ?
Old Thu 18 April 2013, 20:13
you can always set up a test rig with some batteries, a wire of the length you want & some resistors to limit to the current which you want.
1010322S Main Long. Beams - table edge carrying x-rails Gerald_D 10. Base Table 118 Sat 13 June 2015 23:07
I have been wanting to build one of these for so long,... cvriv.charles General - MM Build 66 Fri 13 December 2013 19:35
Build starting in Huddersfield UK November 2012 **table alterations & long Z axis** mattmurphy Introduce yourself and start planning 3 Thu 15 November 2012 05:36
20' long table, 5HP spindle - Port Aransas, USA skypoke MechMates already cutting 42 Sat 09 July 2011 18:07
How many motors use mechmate in the long axis albertoslayer Motors & their mountings 11 Tue 09 March 2010 10:44
