Old Thu 29 January 2009, 12:38
kanankeban
Just call me: Hector #89
Monterrey
Mexico
Messed up while cutting-grinding a rail
Hi guys,
Does anybody knows if 27mm rails will be ok? I spoiled the center of a rail...with a bump...and have to rectify the rails to 27mm instead of 28mm, is there any inconvinience ?
Old Thu 29 January 2009, 19:12
Hector if the spoiled area is small you can add mig weld and file the top back down flat , then continue grinding.
Old Thu 29 January 2009, 20:02
kanankeban
Monterrey
Mexico
Thought it was worst, but after fine checking its just a spot about 2 inches in lenght and 1mm deep, thought same thing as you proposed...just a small weld
Thanks...for the help
Old Thu 29 January 2009, 20:13
It is your choice whether welding or more grinding to 27mm. (The 27mm will also be okay)
