Old Fri 16 March 2018, 21:22
ChuckS
Just call me: Chuck #125
Mt Clemens, MI
Business is booming. I've been making and selling lots of kayak paddles, and a few local (BIG) companies have tracked me down with lots of ongoing work. So far, everybody who has tracked me was through connections I made at TechShop Detroit.
I'm hunting for a building, and may be building another machine or 3. I've not found anything I like better than the MM.
Old Fri 16 March 2018, 21:39
Up late Chuck....
Glad & envy your.....growth.
Indeed. The Cnc world does have this potential to create......wonders & growth...
All the best....Robert
Old Sat 17 March 2018, 03:32
Awesome! I love to hear that someone is being successful with their MM. Keep it rolling Chuck!
Old Sat 17 March 2018, 06:54
ifffff
Just call me: Ivo #38 & #130
Parnu
Estonia
Originally Posted by ChuckS View Post
I've been making lots of kayak paddles
Intresting. Can you put some photos of them? I am doing same job for one customer.
Old Mon 19 March 2018, 08:47
YANLM
Just call me: Yannick #129
ST DENIS
Reunion
hello Chuck #125, i have seen that you have made a vacuum table, have you some photos to share perhaps?
Yannick.
Old Mon 19 March 2018, 20:04
ChuckS
Mt Clemens, MI
Here'a a pic of some of my paddles.
Sadly, I was in too much of a hurry to take pics when I built my vac table. I have 8 zones, but the table is pretty generic. I did use these valves, which I like MUCH better than the typical gate valve. It's powered by a ShopVac. Not ideal, but good enough for what I'm doing.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Old Tue 20 March 2018, 05:01
Nice! I see what you mean about being "busy". Thanks for the tip on the valves. Maybe you could share a picture of your completed vacuum table setup. I'm one of those still "thinking" about a vacuum system.
Old Tue 20 March 2018, 11:55
IamDave
Just call me: Davey
Ball Ground, GA
Chuck can you post a picture of your "Mechmate", for me. or point me to a pic on the forum?Thank you.
Old Thu 17 May 2018, 11:07
IamDave
Just call me: Davey
Ball Ground, GA
Never mind there Chuck #125. I found it.
Old Thu 19 July 2018, 18:37
ChuckS
Mt Clemens, MI
Question-
A few weeks ago, I was getting mis-aligned cuts, which I tracked to a loose belt in my Y axis drive. I tightened the belt, and all was good.
I'm now getting the same problem, so I assume it's the same answer. I'm away from my machine for a bit, and just had a customer notice a stepped cut from a few days ago. (parts are still acceptable- it helps to have great rapport with customers!)
I've been running my MM long and hard- do belts have a life? Or am I just not tightening things well enough?
Old Thu 19 July 2018, 19:07
Cheap belts will have stretch more than a quality belt for sure. However if you did not put blue loctite on the grub/set screws it can cause this also. There is a lot of torque being applied on the pinions so I would look there first.
Old Thu 19 July 2018, 19:24
ChuckS
Mt Clemens, MI
I do have Locktite on the grub screws (added after some slippage early in MM's life), and everything is tight. (As of when I checked 3 weeks ago). Customer says I'm out about 15-20 thou.
My belts are these from B&B manufacturing and are neoprene/fibreglass.
https://www.bbman.com/catalog/product/162XL037G
I'm ignorant of the quality of belts, and not really price sensitive. The machine has gotta work :-)
Any recommendations?
Thanks!!
Old Thu 19 July 2018, 19:42
Working in maintenance we found that Goodyear belts held up the longest to the abuse of heat and work stress. They were acquired by Continental a few years back but still make a quality belt.
If you have an indicator that you can use, running a test to see which axis is the problem. I am unfamiliar with your drive setup without some in depth reading. If it is a gearbox drive then a backlash problem can be present.
If your motor is mounted only with four bolts, it could be pulling it back. Mounting a small steel block with a pusher screw to keep the motor in place is a good option as well. This will keep the belt tension constant.
Old Thu 19 July 2018, 19:59
ChuckS
Mt Clemens, MI
I'm running the 3.6:1 belt drives supplied by Metalhead.
It appears the Y axis is the problem. No detectable error in X. Most of what I'm cutting has square profiles, so it's mostly only moving one axis at a time.
Yup- only mounted with four bolts. I should have thought of the block & pusher screw, but didn't.
Thanks!! I will fab up a pusher block and bolt, and track down some Goodyear/Conti belts.
Old Fri 20 July 2018, 06:58
For what it's worth Mate (Chuck) !!, in my case, I tend to get this (of alignment, or out off spec) occasionally !
In my case, what cause this, is mostly on my "Y" as it get out of alignment.
Many factors I've found through time ( aside others) is, for me, being in northern east Canada, seasoning ( temps changes creates expansion & contraction ) of everything !
Metal, the concrete slab on what the machine sit, indore temps & humd changes with seasons..... on....& on !
So, in a nut shell, through all these years ( 10 now with my babe )....i've learned not to neglect recheck at least 2x per yr (if not 3 x ) the "realignment" !!
Sure, belt may be an issue?!?, not questioning that, but never had for me @_@!!
My 2ct & situation though I'd shared !
All best bud....
Newb in Mt Clemens, MI, USA ChuckS Introduce yourself and start planning 21 Wed 18 January 2017 20:42
