Old Wed 12 May 2010, 05:09
hutchcj
Just call me: Colin
Sydney
10 60 318 Gantry Cable Duct - Can we do away with it?
I've been planning to build a MechMate for some time and I have finally started buying some of the bits, so the build (and posting) should start fairly soon I hope.
Anyway, I've been going over the plans and I was wondering if we actually need the Gantry Cable Duct (10 60 318).
Is there any reason why I shouldn't cut a hole in the Gantry Tube (10 20 440) near the Y Cable Chain end and feed the cables through the Gantry Tube and Stiffening Closure?
Other than a small reduction in stiffness, I can't see a problem?
Old Wed 12 May 2010, 06:13
Colin, that could work. I see some possible reasons to avoid it, none of them major:
- It will be a fairly sharp S bend in the cables
- There are lots of potentially sharp edges to deal with, at your hole, the Stiffening Closure, and the ends of the bolts holding the rail.
- You will potentially be running both high and low voltage through the same "conduit"
- The hole in the Stiffening Closure is fairly small, and could get crowded depending on how much cabling you end up running.
As long as those don't concern you with your plans, I think it's okay.
Old Wed 12 May 2010, 06:50
A couple of guys have done that and discovered that they need to stay out of the way of the y-car's hold-down roller. I don't think that anyone has put spindle cooling pipes through there yet.
I have a problem with the concept of cutting holes in the most critical part of the gantry simply for a small "aesthetic improvement".
Old Wed 12 May 2010, 22:32
Colin,
I actually tried to lay the cables as you mentioned as there are a few missing pieces in my laser cut package.... hope to "get away" with the short coming...
It is actually more difficult then it seems to fit all the cables in the gantry tubes & keep them organised...
I find it easier to lay the cables & organise the cables with the cable duct.
Like you, I question the stiffness of the plastic cable duct, I ended up with off the shelve 3" wide x 1/2" deep metal cable tray c/w cover. cost less then US3 per 8' length. I also fabricated some brackets from my rail off cuts, (could had just bough some brackets as they are not expensive & helps keep a peace in mind) here
BTW, don't get too worried over the seemingly weak cable duct, the most brutal force they will ever experience when you give them the huge yank just to satisfy yourself, after which, you will leave them alone for a long long time
Old Thu 13 May 2010, 02:04
We fit plastic cable ducts to garbage trucks with d/sided tape and that is a good solution.
James Webster's 300VA, 71V, $60 power supply James Webster 702. Power Supplies 6 Sat 18 February 2012 00:00
Belt reduction box build T5 16 to 60 linus1 Driving Mechanisms: Rack/pinion, gears, screws, belts & chains 3 Sun 25 July 2010 08:26
Using gantry tube as a cable carrier dmoore Archives 14 Mon 23 June 2008 23:53
M5 10 160 A & M5 10 200 A Motor Mounting Bolts dmoore Motors & their mountings 3 Wed 16 April 2008 02:06
10 10 302 S - Maximum spacing of cross bearers dmoore 10. Base Table 2 Tue 15 April 2008 06:58
