Old Sun 11 December 2011, 21:10
tangocharlie123
Just call me: Pete
Gatton Brisbane
4th Axis from china
Has anybody had a look at these
http://www.ebay.com/itm/CNC-Router-R...item3cbd993ac5
if so can you give feedback Please
Pete
Old Sun 11 December 2011, 21:18
tumutbound
Just call me: Geoff
Hobart, Tasmania
Pete,
Take a look at this one, very much the same but much cheaper.
I'm looking at getting one for the 6040 CNC router they sell. I have one of these routers but from a different seller.
Geoff
Old Mon 12 December 2011, 06:40
Those seem a little small for the MM; if you're planning on working on small pieces with small bits, it could work, but I would look carefully at whether or not that ungeared nema-25 is strong enough to hold your work in place under cutting forces.
Old Mon 12 December 2011, 10:06
A general "rule of thumb" for any motivated device in a rotary or winch fashion that the motor can be back fed from the part requires either a load brake or a 40:1 gear reduction via a double reduction worm gearbox. Now, this is a really vague rule, but when resisting loads, it nice to know the power transmission can stay put while being used. I'm not an engineer - but my automation mentor beat this rule in my head for years when winching people off the deck. 40:1 double reduction worm is considered "self locking" and doesn't back feed.
So, for instance on my rotary axis that was moving a 4' x 4' x 8' block of foam, I used a 80:1 double reduction gearbox fed with a Nema 34, 4.5A stepper motor. I think it was the PK299-4.5 with exceptional results.
Old Sun 18 December 2011, 02:46
tangocharlie123
Just call me: Pete
Gatton Brisbane
Thanks for the replies and for your input.
Regards Pete
Old Sun 18 December 2011, 14:41
Pete,
You can also see a very recent 4th axis done by Jimmy.
His is moving a fairly small part area (and load) with a 4:1 reduction. I might have been short sighted in not clearly showing the large circumference and load that I was utilizing.
Sorry if I misled you with partial information.
Hi from China mike wang Archives 5 Sun 25 April 2010 02:05
Setting A-axis terminal as X2-axis in EMC2 KenC CNC motion control software 2 Wed 27 January 2010 05:40
From China,new guy delongcnc Introduce yourself and start planning 3 Wed 28 October 2009 18:05
INA and Hepcomotion type track rollers from China Sandy Ye The Market Place 1 Wed 05 August 2009 07:37
Motionking (China) Kim Mortensen 701. Motor Drives 6 Mon 12 March 2007 17:58
