Old Thu 04 March 2010, 08:43
dkrueger
Just call me: Doug
Hubbard Lake, MI
Question Wanting to build a CNC router
I new a this idea, but not new at using cnc machines. I used to work in a machine shop using various cnc machine. I have been thing about getting a cnc for woodworking, making signs. i'm looking for about a 2x4 to 2x8 foot cutting area. Not sure on what kind of cost it takes to build one and how hard it would be. any info would be great.
Old Thu 04 March 2010, 08:47
lumberjack_jeff
Just call me: Jeff #31
Montesano, WA
Up to 4x4 size, consider a Joe's machine.
http://www.cnczone.com/forums/forumdisplay.php?f=346
If you want 4x8 or larger, the MechMate is the best choice.
Old Thu 04 March 2010, 18:55
Do a lot of reading here + quotations around & you will have a ball park cost figure.
Everyone has a different skill level. Build one & you will how how hard/easy it would be.
hope this helps
Old Fri 05 March 2010, 05:12
Doug - Welcome and read around on the forum that stuff is detailed well here. The size you are looking at tells me a standard build machine would work fine for you making signs. Many here do just that with their MM.
Again - Welcome Aboard !!!
Old Fri 05 March 2010, 06:41
Johannescnc
Just call me: John
Hannover, DE
Germany
I would only build smaller if work space limits the size. The difference in cost and work would not be much of a factor otherwise. I would not want to handle material more than necessary. IE, cut on table saw and move to router... (needs an overworked smiley here...)
Old Fri 05 March 2010, 08:38
I agree. One good thing with the standard table is you can use it to size your boards wiht an end cutter and then use the ball nose and v bits to carve the sign.
Newbie looking to build first CNC - WI, USA jpietrowiak Introduce yourself and start planning 4 Tue 07 July 2009 09:35
Small foot print CNC router Art Miscellaneous / General / Whatever / Catchall 7 Fri 28 November 2008 15:11
Customer wanting someone to build a MechMate to spec dneisler Archives 43 Tue 05 August 2008 15:48
CNC Router Tool Height Indicators For Sale JoeyGH The Market Place 11 Thu 06 March 2008 07:42
Help needed to make cnc router - Pakistan Masroor Anwar Construction started, but not cutting yet 19 Tue 30 January 2007 03:32
