#91
This are my screens in Mach3:
#92
Other screens:
#93
When I enter mach3 the reset botton is flashing, presing it lits 3 leds: j15, Output Enabled and J17...the code starts to run, but the motors dont turn...nothing happens!
Forget to say: 1. A is slaved to X already... 2. Motors are energized, check them and they hold also checked with current and its present Last edited by kanankeban; Tue 20 December 2011 at 18:48.. |
#94
It looks to me like those Mach3 settings are a little off. You have port 1 pin 17 shown as enabled for both the charge pump output and the estop input. I would expect neither of those to be on port 1. Do you have two parallel ports, or only one?
Judging from the PMDX-122 manual, you want the charge pump on port 0 pin 17 and the estop input on port 0 pin 10. If that doesn't do it, please give us a closeup of the PMDX-122 with light (or tell us all the jumper settings), and let us know what you have wired into it for limit and estop switches. |
#95
Brad is right that you cant have pin 17 for both charge pump and e-stop, however PORT 1 must be used for all your outputs and inputs (port 0 has no port selected) E-stop is usually Port 1 - Pin 10, and charge pump Port1 - Pin 17
I see on your motor outputs all your motors are set to Port 0 for step and direction - these must be set to 1 (if you are using two parallel ports with a second BOB is the only time you would use these settings as possibly port 2) |
#96
so using 1 in output stop port & dir port is the correct option? estop port 1 pin 10? charge pump port 1 pin 17? Thanks... Last edited by kanankeban; Tue 20 December 2011 at 23:48.. |
#97
Finally Done...It took 3 years......hahaha...The project went two sleep to times, first round was about 2 or 3 weeks, second round other 2 weeks and third round 1week, but the important part is that is done now!...I promise next one ill dedicate more time!
So now I present you with Mechmate #??? http://www.youtube.com/watch?v=6dxAq...1&feature=plcp So...only need to calibrate rails, some tunning in mach, tighten some nuts...and lets make some dust!!!! |
#98
Sweet !!! Let's see it make some dust and put on some logo's and you ready for a serial number !! Great looking built !
#99
It was intended to be about serial number #21 or so.... guess it will be over 100!!!
#100
Does this give me the right for my Serial Number?
Pocketing Letters: http://www.youtube.com/watch?v=IauLB...T5q5AyT89Pl-6J Im Happy!!!! Last edited by kanankeban; Thu 22 December 2011 at 16:18.. |
#101
I believe that you will still need logos on the machine.
#102
I waited long! 2 or 3 days more dont matter
#103
Well done Hector....don't worry your are already part of the club. Enjoy your machine.
#104
Technically that logo is on the machine...???
#105
..yes, well done Hector.
Why don't you just repeat that MechMate pocketing on a piece of scrap and cut a paint stencil.....Done! Bueno. |
#106
The dxf for the logo is in here somewhere. .... Oh look there it is.
#107
Logos are ordered
#108
congratulations Hector
#109
I want to say thanks to everybody in this wonderfull community for sharing time and advice. My special gratitute to Gerald for starting this and all other guys that keep suporting and helping us. The most important thing I learned here actually was not how to build a wonderfull machine, in fact what i learned is that sharing can acomplish great things and this community is a example of it. Thanks again everybody for being so wonderfull guys and Merry Christmas to all!
#110
Logos Attached, Serial Number Please... Im so Happy!!!
#111
Congratulations! Nice!
#112
Hector.
Very Nice. Don't forget to cap off those not used wires on the motor.....you wouldn't want a short to end your day! Bravo. |
#113
Sweet !!! You get #89 !!! Congrats on your build !!!
#114
Congratulations, You have a very nice looking machine there.
#115
Updated Builder's Log
Hector,
I'm so pleased to add my Congratulations to you on completing your MechMate (the first of 2012) and earning Serial #89. Here is the Updated Builder's Log. Please review your Builder's Log Entry and let me know any changes you wish to make. |
#116
Congrats Hector!
#117
Today I added a xyz probe, based on "xyz probe modification" thread on cnczone.com, got to say it works like a charm, everything is there, blue screen set with code in it ready to run. In less than a hour you get the insides and put it to work easily.
Here is the thread if somebody wants it... http://www.cnczone.com/forums/mach_w...ification.html |
#118
Well done Hector!
#119
Thanks...
One of the greatest places where I been... |
Similar Threads | ||||
Mexico's 1st Mechmate Finally is cutting #55 - Obregon, Mexico | Conrado_Navarro | MechMates already cutting | 128 | Mon 18 November 2013 12:38 |
It Cuts the Wood and Aluminum #76 - Guadalajara, Mexico | rceja | MechMates already cutting | 85 | Sun 17 November 2013 06:26 |
3D Elk cutting (video) #13 - Hagerman, New Mexico | Greg J | MechMates already cutting | 415 | Sat 05 September 2009 20:28 |
Upgrading the vBulletin software that runs this forum | Gerald D | Archives | 54 | Mon 20 July 2009 03:26 |
Runs out of steam? Machine freezes during cutting - controlling PC's performance | liaoh75 | Troubleshooting | 11 | Thu 23 October 2008 22:34 |
