Old Mon 02 January 2006, 08:41
Ace Converter (opensource freeware)
An open-source freeware utility to convert two dimensional DXF files to g-code. Doug Yeager of Yeager Automation was the original author, but DAK Engineering also provides a (different?) version of Ace Converter.
Yeager Automation
Dak Engineering
Apparently does:
-Cutting path optimization
-Full four axis converting ability
-Layer by layer cut prioritizing
-Automatic multi-pass generation
-Specify counterclockwise, clockwise or optimal arcs layer by layer
-Turn layers on or off
-Convert to various Gcode formats
But does not do:
-cutter compensation
-pocketing
Old Fri 12 December 2008, 23:01
Thomas00
search-and-destroy
Most people will start to notice their computer starts to slow down and they may also get more advertisements popup when they are browsing. Spyware is famous for making computers run a little “sluggish” - this is one of the first signs that your computer is infected.Then use www.search-and-destroy.com which would be a silly thing to do!
Thank you,,,,,,,,,,,,,,,,
Old Fri 12 December 2008, 23:28
Above is an example of the type of spam that needs to be removed from a forum. When seeing such posts, please use the button (report) on the top right of the post.
