Old Tue 30 December 2008, 07:26
Jeff & Erick, what you experienced with the laser cut parts snapping together is the power of CNC cutting. Realise that one day you are going to make wood parts that just snap together . . . . . .
Old Tue 30 December 2008, 07:29
Psst, Erick; your old man has put lots of pics of you up here - can you put a pic of him over here?
Old Wed 04 February 2009, 20:23
jeffa
Just call me: Jeff
Iowa
Cool We've been quiet, but we're still moving forward...
The MechMate in eastern Iowa continues to move forward. I know we owe the forum some updated pictures. This will follow in the next few days.
Here are some pictures of the 350 mm 'Z' slide...
Regards,
Jeff
Old Wed 04 February 2009, 20:34
jeffa
Just call me: Jeff
Iowa
As you can see, we used the V-rail on the 'Z' slide also. In doing so, the "tip" of the "V" is moved .188" higher on the assembly. This causes a pretty tight fit between the rectangular tube on the 'Z' slide and the inside of the spider.
Regards,
Jeff
Old Wed 04 February 2009, 20:47
jeffa
Just call me: Jeff
Iowa
To regain Gerald's original design clearance between the 'Z' slide tube and the inside of the spider, we remade the 6 Bearing Support Bases to a height of .625" instead of the 11mm (.433") shown on drawing M1 20 220 T B. This seemed like a good solution and looks to have worked out well.
Regards,
Jeff
Old Wed 04 February 2009, 20:58
HomeMadeCnc
Just call me: Tim
Calgary, Alberta
Thanks for the updates and great pictures. This is my next assembly to tackle.
Keep up the great work,
Tim
Old Wed 04 February 2009, 21:17
Jeff your solution to the interference problem looks interesting. Some nice progress there!
Old Wed 04 February 2009, 21:34
lunaj76
Just call me: Justin #24
Littleton, (Colorado)
Great pics and progress!
Old Wed 04 February 2009, 22:09
Thanks for the feedback Jeff & Erick
I was wondering on the weekend how you guys were getting along.
Looks like the V-rail on the z-slide is becoming popular. Sometimes the rail on the front, sometimes on the back. Maybe I need to make a set of drawings for that option . . . But, as you found, fiddling with the height of the support bases makes it all work out.
Old Thu 05 February 2009, 02:46
Jeff and Erick
Those pictures of all the V Rails and the button screws bring back memories. Lots of drilling and taping. It makes a heart feel good to see copies.
Good work. Your build is looking good. It won't be long before you will have a breathing, wood eating machine.
Old Sat 04 July 2009, 19:01
jeffa
Just call me: Jeff
Iowa
Back in the MechMate mode!
Hello again to all.
It's been a while since we've posted on the MechMate Forum. We had a very busy spring this year so unfortunately, we were not able to make too much progress on our machine.
However, we worked on it every now and then, when we could. Also, I've continued to lurk around the forum almost every day to get my MechMate fix... Finally, it got to be too much for me and I had to make another push to move closer to completion.
Here are some photo updates of our progress...
The 'Z' axis moves smoothly through all three sets of V-rollers...
Old Sat 04 July 2009, 19:11
jeffa
Just call me: Jeff
Iowa
We were able to get the base frame welded and the V-rails bolted to the aluminum angle. I still need to spend some time getting all of the axis to roll flat relative to the plane of the base table cross members...it's pretty good, but I think with a little more tweeking, I'll be able to get it almost perfect.
We also got the supports for the cable chain welded and attached. And, as you can see, we also got the cable chains fitted.
Old Sat 04 July 2009, 19:19
jeffa
Just call me: Jeff
Iowa
We will be mounting the electrical cabinet on vibration isolating mounts. Here are a couple of photos showing this scheme...
And one photo of the electrical cabinet mounted in position.
Old Sat 04 July 2009, 19:26
jeffa
Just call me: Jeff
Iowa
Just a few last items to finish up and the machanical build will be done.
With any luck and a little more time this weekend, I should be able to get the proximity sensor mounts done and the 'X' axis racks mounted (we already have these welded up to length...we just need to drill a hole in the ends of both racks).
Old Sat 04 July 2009, 19:35
Looks like pretty good progress to me! Well done guys!
Old Sat 04 July 2009, 19:37
jeffa
Just call me: Jeff
Iowa
Everything fit together so well and all axis roll as smooth as butter. A few more hours and we should have the mechanical build done and we can put some blue paint on her...(which will be really good since, as you can see from some of our photos, it's starting to rust a bit).
It's been great getting back into our build!
I was able to purchase an almost new 5 HP HSD ATC spindle off of eBay and I just ordered and received a Delta VFD from the guys at PDS.
Almost time to start the really fun part....
Jeff
Old Sun 05 July 2009, 00:59
Beautiful stuff, Jeff & Erick! Nice to hear from you again.
Old Sun 05 July 2009, 12:23
jeffa
Just call me: Jeff
Iowa
Thanks Gerald,
It's nice to be making some forward progress and contributing to the forums again. It sure helps to have the helpful community here to keep us going. Hopefully we'll be able to have our Mechmate moving under it's own power before too long.
Best regards,
Jeff
Old Sat 11 July 2009, 17:23
jeffa
Just call me: Jeff
Iowa
Blue...Blue Day (part one)
Started to disassemble our machine today to begin the painting process.
I thought I would get a shot of one of the tops of our 'X' axis rail beams. I used a very straight piece of bar stock along with some mark-up paste (blue steel ink), a belt sander and a couple of good squares to bring the tops very close to "true" for the mounting of our 'X' axis rails. We may have to shim a bit, but I hope it is minimal.
This may not have been a necessary step, but I couldn't help it...just my nature I guess...
Jeff
Old Sat 11 July 2009, 22:47
jeffa
Just call me: Jeff
Iowa
Blue...Blue Day (part two)
We started to paint some of the machine components today.
One benefit from building your own MechMate that I've never heard mentioned in the Forum is that if you do things just right, you'll have a pair of shoes to match your new CNC router.
Best regards,
Jeff
Old Sun 12 July 2009, 01:16
Elvis and his blue suede shoes?
Old Thu 07 January 2010, 19:53
jeffa
Just call me: Jeff
Iowa
Red face We're still alive and kicking.......
Well, at last, a long over due update...and confession...
You may recall from one of our last posts that we were in the process of trying to "tune" our X axis rails and their mounting surfaces in an effort to make the Y axis gantry roll very flat relative to the base table cross members. We were able to get it very close (within about + or - .015" over all areas of the base table cross members). However, no matter how much we tried, we could not get it any closer.
That's when I realized that a "short cut" we (I) had taken on the aluminum rails had come back to bite us in the butt. Because the square-inside-cornered aluminum angle was not as readily available, I purchased aluminum angle (6061 T6) with the radius in the inside corner and I tried to nibble out the radius corner to a square corner with the table saw. Bad idea... This caused the mounting surface for our V-rails to float up and down and created a rail height that was all over the place. Our Y axis rail were able to be salvaged. They are short enough that we were able to mill out the inside corner and remount the V-rails.
Here's a photo of one of our Y axis rails after it was fixed...
Old Thu 07 January 2010, 20:05
jeffa
Just call me: Jeff
Iowa
Remaking our X axis rails
Our X axis rails were unable to be salvaged so I ordered the correct aluminum angle this time (I know, I shouldn't have deviated from the plan) and a new set of V-rails.
Here we're tapping the new set of V-rails
Old Thu 07 January 2010, 20:08
....ooohhhhh I want a tapping head like that! I had one...then it went missing!
Very nice work. I am watching intently. Only a choice few have the alum rail base and preground rails on top. Good luck!
Old Thu 07 January 2010, 20:23
jeffa
Just call me: Jeff
Iowa
Setting the height of our X and Y axis rails
Here are a couple of photos of the process we used to set the height of our X and Y axis rails.
First, we bolted our V-rail to our aluminum angle and placed a clamp between each bolt location.
Next, we tightened each mounting bolt and then measured the height of the rail between each mounting bolt.
After determining what the best natural height should be, we adjusted the V-rail up or down by filing a bit or lifting a bit to set both sets of rails to the same height. We were able to set the rail heights to within + or - .0005" along the entire length of each set.
Old Thu 07 January 2010, 20:30
jeffa
Just call me: Jeff
Iowa
Painting X and Y rail with clear-coat
Both sets of rails are much, much better now.
We are spraying each with clear-coat (no paint on the roller or gear surfaces) and we hope to begin final assembly tomorrow and over the weekend. We have many of our electrical components and we hope to begin laying out our electrical cabinet very soon.
Until our next update (which we hope will be sooner than our last)...
Best regards,
Jeff and Erick
Old Thu 07 January 2010, 20:38
jeffa
Just call me: Jeff
Iowa
Sean,
The tapping head in the photo is just a cheap-o unit from Harbor Freight, but it works quite nicely.
Jeff
Old Fri 08 January 2010, 02:17
Claudiu
Just call me: Claus #43
Arad
Romania
Professional looking machine...really nice job.
Old Fri 08 January 2010, 02:27
I will just repeat what I said 6 months ago:
Old Fri 08 January 2010, 19:52
jehayes
Just call me: Joe #53
Whidbey Island, Washington
Looking very good Jeff: Nice work
Sold to a new home!! #46 - Netherlands riesvantwisk MechMates already cutting 202 Fri 09 October 2015 20:31
It runs! #89 - Monterrey, Mexico kanankeban MechMates already cutting 118 Tue 17 January 2012 18:42
Moved to New Shop to Do Real Work! #81 - Damietta, Egypt 234ahmed MechMates already cutting 83 Wed 28 September 2011 12:20
Had a good day on the girl today! #45 - Melbourne, Aus rnixon MechMates already cutting 63 Mon 16 May 2011 14:54
The control box is completed and the painted table moves! - Ft. Worth, Texas kn6398 Construction started, but not cutting yet 52 Wed 04 March 2009 22:22
