Old Fri 01 March 2013, 09:41
IMMark
Just call me: Mark #119
Columbus Ohio
Control box design, positive pressure
Any opinions on this setup,
control box is 28" x 28"
Using the positive pressure style, and with the "heat rises" theory.
I would put filters on the bottom of the box (outside), with fans drawing air in.
An exhaust hole on the top (covered to avoid dust).
My thought was to locate the drives near the bottom (again, assuming this will be the coolest place in the box).
With the drives placed on an aluminum heat sink (with risers to promote air flow all around them) , does anyone also use heat sink grease?
I also thought that the PS should be towards the bottom as the next potentially "hot" item.
I am planning to wall mount the box and having the CPU in a separate box.
Any feedback is appreciated.
Mark
Old Fri 01 March 2013, 14:20
I have the finned heat sink on the side of my control box, with the Geckos mounted on it.
No cooling fan whatsoever.
I personally think a vented box in any fashion is overkill.
My machine ran fine in 100+ degree summer heat, and last time I opened it, it was as clean as the day I closed it.
Old Fri 01 March 2013, 15:53
I have heat sinks and think that is the best approach.
Old Fri 01 March 2013, 16:40
IMMark
Columbus Ohio
Thanks Darren and Mike.
Mike is your heat sink finned also...is that needed, or would 1/4" aluminum plate work? Also I would think heat sink grease would be a good idea...can't think of a down side?
Mark
Old Fri 01 March 2013, 17:20
I believe Mike sells a nice finned heatsink.
Old Fri 01 March 2013, 17:49
I have a piece of aluminum that the geckos sit on and a fan below them in a sealed box. I have had no problems with heat and no dust is getting in.
Old Fri 01 March 2013, 20:39
Regnar
Just call me: Russell #69
Mobile, Alabama
I have a 1/4 piece of aluminum as well with no outside air. Box is as clean as the day I sealed it up with no problems at all.
Old Sat 02 March 2013, 13:26
IMMark
Columbus Ohio
Thank you for the feedback. Sounds like this is an area I don't need to put the extra effort, time and money into.
As always, I appreciate everyone's help on the forum!
More questions to come
Mark
Simple gear design ?? alan254 Graphics & CAD 6 Wed 23 May 2012 22:12
Own design now cutting in Portugal pinhocareca Miscellaneous / General / Whatever / Catchall 11 Mon 02 May 2011 05:36
Some great CNC design work WTI Miscellaneous / General / Whatever / Catchall 9 Wed 16 March 2011 21:25
A door design fabrica The Show Room 2 Tue 01 May 2007 12:37
Z-axis design Dick van Randen Archives 4 Sun 03 September 2006 13:35
