Old Sun 02 June 2013, 13:42
ilmataat
Just call me: Ivo #120
Jõgeva
Estonia
Stair Beam Machine !!! #120 - Jõgeva Estonia
I started construction last year. In this time i haven't camera to make photos but some pictures i found. Today is almost ready, i have to make last painting and srew it together.
I upload soon the latast pictures.
Table size is 5,4x1,6 meters
Old Sun 02 June 2013, 21:03
I would say welcome, but I can see you have been with us a while !!!
Cool skate mod ... !!!
Old Sun 02 June 2013, 22:08
ilmataat
Jõgeva
Estonia
Yes this original skate, whit height adjustment bolts dosen't work. Because result of grinding is not smoot.
Old Mon 10 June 2013, 09:29
ilmataat
Jõgeva
Estonia
Now is metalwork is done. I have to make controlbox and conect motors and spindle.
Old Mon 10 June 2013, 10:06
Nice!!!
Old Mon 10 June 2013, 14:38
Interesting hybrid Z slide.... can't really tell from the pic, if that is running on V guides or what ?
Old Mon 10 June 2013, 22:00
ilmataat
Jõgeva
Estonia
No whit linear bearing. For some reason i dont trust this original z axis.
Old Tue 11 June 2013, 01:08
Would you care to post some larger pics on the Z ? I am trying to figure out what to do myself ( I am also doing my Z with bought linears), and curious to learn more from all kinds of different solutions I have seen on the MM to come up with my best solution.
Old Tue 11 June 2013, 09:05
ilmataat
Jõgeva
Estonia
I can upload pictuers and detali drawings in weekend becaus i'm now in finland.
Old Tue 11 June 2013, 09:33
Sure, no worries.
Old Wed 12 June 2013, 03:36
Ivo why black and red
I must say I regret every second of painting my machine black and red as it always looks dusty even if not used for routing a day.
Complete white, gray, Blue or yellow in that order are my preferable colors from now on
Old Wed 12 June 2013, 09:07
ilmataat
Jõgeva
Estonia
I think, it's not problem. Because this machine is desinged for working and it's not decoration.
Ofcorse evryone has their opinion.
But thanks for warning!
Old Tue 16 July 2013, 11:14
ilmataat
Jõgeva
Estonia
Little progress, mine watercooled spindle is no arrived jet. But machine is alive. And i have to finish mine vacuum table .
Vacuum pump: 2.2kw
http://www.mechmate.com/forums/attac...1&d=1373994702
Old Wed 04 June 2014, 12:32
ilmataat
Jõgeva
Estonia
Little progress...
List of work that needs to be done:
Limit switches
Computer console finishing and mounting
Change cable carrier(To small cable chain)
Start, pause, stop Pushbuttons
4 th axis
And some little things
Old Wed 04 June 2014, 12:59
I like your control cabinet.
Old Wed 04 June 2014, 13:02
sierra347
Just call me: Armando #110
Montgomery, IL
Very nice
Old Wed 04 June 2014, 19:11
Rapid
Just call me: Rapid
Pennsylvania
I see you Modified the gantry raising it up a bit for clearance. Nice long table. Nice neat control box with 5 drivers. Your steppers look big !
Looks great ... I hope you will soon be making money with it !!!
Old Wed 04 June 2014, 21:04
ilmataat
Jõgeva
Estonia
Yes steppers are to big. In future i planed to change other 3 steppers also 878 oz. Right now are there 1600 oz x and y axis. Z axis have 878 oz stepper.
First cuts are maded half year ago. It maded so long for stair beams, whitch are main jobs for this macine.
Everything is preparated for 4 th axis. I made electicbox for 5 drivers. Just have to install lathe chuck and wiring.
Only problem is vibration now. But those 1600 oz stepers needs to run higher speeds. In low feed rate they vibrating. Or ther some other problem?
Old Wed 04 June 2014, 22:08
I suspect the motor vibration comes from the motor driver. High torque stepper motor do have this resonance short fall.
878 oz stepper motors are still too big, I use 640 oz direct drive without lost step for years.
Not that I oppose going way oversize, but just tot you might feel comfortable knowing.
Old Thu 05 June 2014, 09:29
Rapid
Just call me: Rapid
Pennsylvania
Ivo... so machine is designed with long table to cut stair beams.
.... we call them stair stringers here in the USA
http://www.bing.com/images/search?q=...gers&FORM=IGRE
http://www.bing.com/images/search?q=...lectedIndex=64
Old Thu 05 June 2014, 12:54
ilmataat
Jõgeva
Estonia
Thanks fo correcting... mine english is not bestest.
I use stair drawing's software and there it called Beams.
At the moment, about 10 stair detalis are cutted whit this machine.
Much easier then make it by hand and powertools. And also time and precision factor.
Old Thu 05 June 2014, 14:44
Rapid
Just call me: Rapid
Pennsylvania
Other English speaking countries may call them something other than stringers.
Sometimes called stair horses ... especially if there is a beam between the outer beams (stringers) but I think the outside beams can be called horses also
I did not know there were softwares for cutting them on a router
http://www.bing.com/images/search?q=...electedIndex=6
Old Fri 06 June 2014, 23:09
Very well done Ivo!
(you have obviously earned a serial number)
Old Sat 07 June 2014, 00:18
ilmataat
Jõgeva
Estonia
It shoud be 120?
Old Sat 07 June 2014, 01:59
Ivo, congrats on a very nicely done build. I just now have looked at your thread and it is a beauty of a machine.
Old Sat 07 June 2014, 08:16
silverdog
Just call me: Sergio #70
Rome
Italy
"Sat 07 June 2014, 07:09"
This is a very nice news and surprice !!! :-)
Old Sat 07 June 2014, 17:33
parrulho
Just call me: Paulo #108
willemstad
Netherlands Antilles
Congratulations. Very nice long machine.
Old Sat 07 June 2014, 17:39
parrulho
willemstad
Hi Gerald, nice to see you here again.
Old Sun 08 June 2014, 21:03
Ivo that is a nice build !! And yes you get #120 !!!
Congrats on your build. Looking forward to see some project pics.
Old Sun 08 June 2014, 23:33
jask
Just call me: John
Kamloops B.C.
x2!!
Congratulations Ivo!
Cutting Gears on Two MechMates! #38 & #130 - Parnu, Estonia ifffff MechMates already cutting 197 Tue 20 November 2018 18:44
Hi from Estonia! v2ikekresu Introduce yourself and start planning 10 Fri 26 August 2011 09:05
X Rail I beam thickness?? sierra347 10. Base Table 1 Tue 17 May 2011 18:26
Problem with Main Longitudinal Beam gixi 10. Base Table 32 Thu 19 November 2009 14:23
Location and spacing of X rack from main beam? dmoore Driving Mechanisms: Rack/pinion, gears, screws, belts & chains 3 Sat 26 April 2008 23:44
