Old Sun 14 February 2010, 19:40
cordell
Just call me: cordell
johnson city,tn
Up and Rolling - Johnson City,TN
Hello Everyone, this is my first post as a builder,been reading and looking over the plans for a while, I have been off work for a week and thought it would be a good time to dive in and get started. My table is 49"(1244)x97"(2463), and will have 3:1 belt drive, parts were purchased from leo,and what a great job on the cutting and bending. I changed the cross bracing to 2"x2"x1/4" because I already had these , hope it dont cause a problem, I can change them later if problem arises, seems very strong though, I am in the process of grinding the old rails, the fun stuff! ,used about 6 disk on one y rail, going to have to get some good disk for sure,I think everybody should at least grind a set of rails just to kinda pay your dues, will try to post pictures a little more often, thanks everybody for all the great information and thank you Gearld for this great site.
Old Mon 15 February 2010, 04:36
Welcome !! Nice base table.
Old Mon 15 February 2010, 06:39
Cordell,
Welcome to the Forum. Looking good.
I used Dewalt disks. I only needed 1 disk for grinding the rails. So your point about using good quality disks is a good one.
BTW, my brother lives in Mountain City.
Old Mon 15 February 2010, 11:28
Welcome Cordell! Seems you are off to a good start there!
Old Mon 15 February 2010, 20:35
cordell
johnson city,tn
thanks guys for the welcome,and thank you John for the heads up on the dewalt disk, made a world of difference, cut the other y rail and wore down a little over 1/8 ",I'll be glad when these are finished!
Old Sun 28 February 2010, 22:19
cordell
johnson city,tn
she's up and rolling, got the rails ground, it wasn't as bad as I thought it was going to be, with a good disk for cutting and a good mind set it went pretty well, with grinding the v, I used a 36 grit sanding disk, for me it seem to work great, waiting for some electronics to arrive ,In the mean time I will try to spread some blue paint on the old table.
Old Mon 01 March 2010, 06:28
Cordell,
Looking good...and fast too.
Old Wed 17 March 2010, 20:44
cordell
johnson city,tn
Z-plate finished ,milwaukee bracket made
haven't had a lot of time to work on mm lately, which is a good thing, work seems to be picking back up, got the reduction boxes finished, z plate ground and tapped and destroyed a good router base to make a mounting bracket , I've got more time than money, so went ahead and cut it up, the height adjustment is still in tack, dont know if ill ever need it , heres a few pics.
Old Thu 18 March 2010, 03:00
I like your quick release bracket. Did that come with the router ?
Old Thu 18 March 2010, 05:00
Yeah where did you get that bracket?
Old Thu 18 March 2010, 06:51
bolingerbe
Just call me: Bryan #54
Clinton(Tennessee)
Looking very good.
Old Thu 18 March 2010, 09:53
Johannescnc
Just call me: John
Hannover, DE
Germany
Very ingenious! I like it!
Old Thu 18 March 2010, 15:09
Ok - now I need to know. Can you sorta lay out the steps you did to make the bracket? Is it the one that came with the router.
Did you need to fab any parts?
Why I ask is becuase if it is the one that came with the router , this could be a cost savings for mounting this type router (which most like) and would be a great thread to detail out how to do it.
Old Thu 18 March 2010, 16:28
cordell
johnson city,tn
hello guys, here is a couple more pics, and I'll try to explain, the clamping part is the top of the original router base that has been cut into, the black bracket was constructed mostly from 2x2 sq tube ,shown in the pic, some lines have been drawn showing how I cut the tube to make the parts, the rounded corners works good , to of the corners was used inside the router base for clamping strips, similiar to the clamp strip in the y rails. took about three hours to make. I first cut the base where I wanted it then attached two angles to it with clamping strips,then added the back plate, then the inside corners are diagonally braced. everything was TACK welded in place on the router base before removing to weld. after removing to weld, clamp something across to decrease distortion, the housing where the clamp strips go are tapered a little, bit so when tack welding the back plate on, square the plate with the top of router base this should get you parallel with the z plate when mounting, sorry for the poor pics, need better camera and lighting, oh forgot , had to add 1/2" spacer to the back to allow clearance for bearings on spider.
Old Thu 18 March 2010, 19:21
That is cool.
Old Fri 19 March 2010, 03:00
Brilliant work! Simple touches & keep the original holder useful. Thats what I call value engineering!
Old Fri 19 March 2010, 09:27
I wish I was this good at fabricating things. Well done, I like it.
Old Fri 19 March 2010, 10:49
cordell
johnson city,tn
Thanks , everyone for the kind comments, hope it holds up under cutting conditions. looking forward to getting to mess with some electrical components, will need some help along the way for sure, hope not to be to much of pain for you guys, again, Thanks
Old Wed 07 April 2010, 20:02
cordell
johnson city,tn
hey Bryan, thanks for the pm's and checking in on the project, been working 6/12's at work, not a whole lot of time for anything else, still have a little bit of painting to do on main table, getting ready to start control box, where is a good source for power cut offs, switches and all that good stuff? here is a couple pics where I am on the build.
Old Thu 08 April 2010, 13:00
bolingerbe
Clinton(Tennessee)
Electronics suppliers
Cordell,
I would start at the links below.
http://www.factorymation.com/
http://mouser.com/
http://www.grainger.com
Inspired by Multicam, Y Car Mounted - Randers, Denmark Kim Mortensen Miscellaneous / General / Whatever / Catchall 308 Mon 08 May 2017 05:37
IQChallenged - Chattanooga, TN iqchallenged Introduce yourself and start planning 3 Sun 05 April 2009 06:35
Another enthusiast newbie - Redwood City California Stephen Hull Construction started, but not cutting yet 2 Sun 25 May 2008 04:05
Mass and rolling resistance of moving the gantry Gerald D Driving Mechanisms: Rack/pinion, gears, screws, belts & chains 21 Fri 02 May 2008 06:01
New Project - Salt Lake City, UT - Input Encouraged! crushmonkey Construction started, but not cutting yet 1 Thu 18 October 2007 01:00
