Old Thu 09 December 2010, 18:31
bwp
Just call me: BW
Garrison, ND
Is a newby from North Dakota welcome into your team???? Ha, I am just next door to Minnesota. Just call me BW
I am looking to build a smaller version of the MechMate. Dimension 36" X 36". I plan to use this to machine the master molding plates for casting parts. All of the finished parts are no more than 2 inches thick when the casting is finished. So the machining would be no more than that, and usually only half that thickness. Is that something that is doable with this machine. Thanks BW
Old Thu 09 December 2010, 20:59
The machine can handle it no problem, but 4x4 is really about as small as you can take our design. But I am sure you would be happy with that size machine.
Welcome to the group !!!
Old Fri 10 December 2010, 10:01
BW,
As detailed in a number of machine builds, you will find the best width (gantry) is the 48" dimension as a minimum. The will benefit you in many ways, but mostly resale value. If you were to re-market the machine, adding a new machine bed that is longer will allow you to accommodate the most common USA sheet good size of 48 x 96.
Good luck.
Old Sun 12 December 2010, 18:50
bwp
Just call me: BW
Garrison, ND
Right now I just don't have enough room to put a larger machine in. Giving up the additional space would cost me money. I have over 20 machines and support equipment and tooling in my small 3200 sf building, with a dozen machines outside getting rusty. So larger is out of the question. All of my master plates are 24 x 24 so a 36 x 36 size is large enough for my needs. I want to build something that is stout enough to machine wood and/or aluminum. What I really need is 20,000 sf, but who can afford it in this ecomony. If I decide I need a larger machine later, I will build a larger one, and take this one home and use it to cut decorative door panels or something else. BW
May JR's legacy continue #4 - North Carolina, USA J.R. Hatcher MechMates already cutting 610 Tue 22 July 2014 11:06
Out of the shadows - Pacific North West, US ChiknNutz Introduce yourself and start planning 22 Wed 06 January 2010 20:22
Add one more CNC addict - North Carolina rodom Introduce yourself and start planning 0 Tue 01 December 2009 05:54
One more MechMate starting - North Carolina, USA Bernhard Construction started, but not cutting yet 5 Fri 28 December 2007 15:11
Newby question re driving one side fieldknot 10. Base Table 1 Wed 05 September 2007 22:55
