#271
Good work Anil .I think you should put some shellac or varnish on your carving before staining so the wood wont absorb all the stain at once .Then you could whipe the excess on the high part of the sculpture and the stain will remain in the crack and low spot .
#272
Some 3d cuts for this weekend, before anyone ask http://cnc3dart.narod.ru/free.html is where I got the files, I think this link is mentioned somewhere in the forum already
Total 7 Hours with 4mm ball nose in 25mm thick mdf with no roughing pass. 3d6.jpg 3d7.jpg 3d8.jpg 3d1.jpg 3d2.jpg 3d3.jpg 3d4.jpg 3d5.jpg Still not sure about staining/finishing as these are cut just for fun and not to be used anywhere!! |
#273
beautiful - you are having fun with MM!
#274
Sure Irfan, Its fun
I used sealer (as its called locally) and mixed some color powder to it. Last step I coated with a layer of PU clear-coat to give it shine. horse-s.jpg |
#275
Hi Anil It look better ,try again with the dark stain .Apply a generous coat and whipe out the excess on the high spots ,it will leave reveal the detail with more contrast. Sinse it is already varnish the stain wont soak in where you dont want. Let dry and repeat until you are satisfied . Depending on the stain you use you might have to varnish again so it does not come off. I see some vertical lines are they from the design or glue up plank or missing step?
#276
Sure, It is going to take few tries
Those vertical lines are from applying clamps while machining was on the way , the material left after 3d machining was very little (may be 1 mm) and the as the cut progressed it started to wrap and lift up, I tried to correct it by applying additional clamps, not thinking of that these will leave marks on the end product |
#277
More fun
puzzle1.jpg Next logical step is to do something about dust, so planning to use my vac. For sure this weekend project ! |
#278
hi anil
congrats for ur build, sorry i followed late. |
#279
Thank you Singh, By the way whats you plan about building MM ? you started it yet or not ? If yes then I am waiting to see some shots of your build
#280
Another one :)
Oops, I said next is dust foot but kids wanted something to play !!
horse-puzzle.jpg |
#281
Anil,
Very nice horse. |
#282
DS works great :)
Thanks Nils
Moving to MM, could not complete dust foot today but flexible pipe and dust separator installed and it works great I was amazed to see no dust in vac bag at all, all the dust collected in bucket ! so I just removed the filters from vac. I guess it will reduce the load on vac motor and I could be able to run the vac a bit longer. Output from vac also routed to outside of room so even if there is a bit of dust it directly goes outside. ds1.jpg ds2.jpg ds3.jpg ds4.jpg |
#283
thats too good
#284
Anil,
This is the height of using MM, Making lid for the Bucket????? with a separator???? All the creations are good. Be a machine designer. Do not become an end user. You will kill other competitors. . . Great Going Keep It Up. All the best for your next machine. |
#285
There is nothing wrong with making lid with MM because that what MM is intended to do, cutting curves !!
There is not going to be NEXT machine as I have no space left for that, but for sure next thing is to do a rotary axis for MM and then convert my small metal lathe to CNC |
#286
Great thinking. Eager to see rotary axis on MM. I have seen one in the Wood India 2010 exhibition which concluded on Monday. All the best. This is what I meant by Machine designer. Just Keep Advancing.
#287
hello anil ji.
where can we get gecko drives in india. jit |
#288
Hi Jit,
I don't think you can get Geckos in India, you need to import like others or like me you can go DIY route now and may be later get Gecko if you feel so I am happy with my drives and don't feel need Geckos for now. If you feel I can be of any help, you can call me (965 444 3210) |
#289
Can't you get Motion King in India?
Mike |
#290
Mike, I don't know for sure but while talking to someone I was told that even if its available the price is going to be far more compared to getting it directly from MK even after factoring in the shipping/customs etc.
May be Irfan or other member from India using MK can tell better, I am going to ask him. |
#291
anil ji
what is the acurracy of your driver and how much it cost you in rs/- ,plz if u feel free can brief about the costing of full project of yours beautiful mechmate.(stepper+driver+bob+ps+fabrication+ software) jit |
#292
sir,
plz share the further developments of your mm and some of the beautiful cuts |
#293
Thanks Jit, PM'ed you.
As the MM seems functional now, I am trying to learn more about stepper and servo drives in order to make driver using descrete components that's not limited by 3A limit of LMD devices used in current drives. |
#294
A little update :)
Polished and installed the divider screen, This is my first attempt in staining and polishing so nothing creative..
#295
Thats cool. Keep going.
#296
Lovely!
#297
Black and blue!
#298
Beautiful
Great Anil, Looks beautiful. good detailing.
#299
Just to say hello :)
Hello everyone, been busy and not able to follow, seems like there have been many numbers after me. Trying to catch up ...
#300
Hi Anil, I think I was near your place over the weekend. I was in Gurgaon for business. How are things going?
Similar Threads | ||||
My Mechmate coming up - India | Manjeet Singh | Construction started, but not cutting yet | 13 | Sat 24 May 2014 22:49 |
Checking continuity of wiring with Antec Power Supply Connected | oliver2257 | 702. Power Supplies | 0 | Wed 30 November 2011 15:52 |
New Guy from India | ksgpathi | Introduce yourself and start planning | 1 | Wed 26 January 2011 14:56 |
Checking Parts List confirmation of pinion & gearbox | DocTanner | Motors & their mountings | 21 | Fri 09 February 2007 11:53 |
