Old Thu 27 May 2010, 09:25
congrats! Good looking machine, nice first cut!
Old Thu 27 May 2010, 16:44
Builder's Log Update
Sergio,
Congratulations on your MechMate and for earning Serial #61. Well done!
Please review your entry and let me know any changes you want to make.
Old Thu 27 May 2010, 17:09
WFY
Just call me: Buzz #60
Pembroke, Ontario
From #60 to #61 great job Sergio - I think you need a new helper looks like you wore the one in the picture out! Maybe he can get a job in Hobbit land.
Old Fri 28 May 2010, 00:10
Sergio-k
Just call me: Sergio #61
Athens
Greece
Thanks again all.
At this stage i'm experimenting with the bits.
Broke 2 ,burned MDF, and fired my helper
From the testing i concluded that the Onsrud 65-000 series is doing amazing and clean cuts on MDF.
I used the 65-013 bit with 18000 RPM and 1600mm FR and it was like cutting into butter.
The 53-040, 63-040, 46-008, and 38-50 all of them burned the MDF on 18000-15000 RPM 1600-1000 FR.
The 52-040 simply broke.
Operating a cnc machine is a whole diferent thing from making one,
but errors is a must for getting into experienced mode i think .
Old Fri 28 May 2010, 13:33
dragonfinder1
Just call me: Dave #49
Astoria, Oregon
Do a google search for chip load calculators, there are many free ones. They will help with the burning of the wood or the tool. Most likely is that you are turning your tool too fast, and or feeding too slow. That was my problem, I had to speed up the feed to a dangerously fast feed rate, or at least I thought so when I first started cutting.
Dave
Old Fri 28 May 2010, 20:12
dragonfinder1
Astoria, Oregon
Here's a link to the one I use
http://www.vortextool.com/images/chipLoadChart.pdf
Old Sat 29 May 2010, 02:20
Sergio-k
Athens
Greece
Thanks Dave
I allready used chipload calculator based on the
pdfs provided by Onsrud : http://www.onsrud.com/xdoc/FeedSpeeds
What i'm trying to figure out is why for example a certain bit is doing an
excellent cut on 25mm thick mdf but burning the 4mm one with the same speed and feedrate.
Sergio
Old Sat 29 May 2010, 05:16
Congrats! You have a beautifully built MM #61 there! Now go burn some cutting bits & make some wood dust!
Old Sat 29 May 2010, 07:12
dragonfinder1
Astoria, Oregon
Sergio
I can't help you on that one, I cut 6 - 10 mm on a pass and the only time I burn a bit is when I have too small a chip load, never burned one with too big a chip.
Good luck'
Old Wed 02 June 2010, 01:22
Claudiu
Just call me: Claus #43
Arad
Romania
Great looking table, Sergio. You did a great job there. Have fun cutting.
Old Thu 03 June 2010, 07:08
liaoh75
Just call me: David
Taibao
Taiwan
Well Done Sergio! Your build is a beauty.
I'm BACKKKKKKK!!!! - Houston, TX swatkins Construction started, but not cutting yet 136 Tue 04 August 2020 23:08
One year later - a report back #29 - Manitoba Canada astrolavista MechMates already cutting 33 Fri 13 August 2010 14:58
Construction started - Greece foinikas Construction started, but not cutting yet 20 Thu 31 December 2009 10:13
Hi From Greece (Planning Started, Advise Needed) Sergio-k Introduce yourself and start planning 15 Tue 17 November 2009 11:35
Terrible thing to see gmessler Archives 2 Fri 23 November 2007 14:33
