Old Fri 06 November 2009, 13:22
Mitch_1
Just call me: Mitch
Sussex
Send a message via Skype™ to Mitch_1
Easy Torroidal Transformer
Hello Guys....possibly gals....?
I need a source for a toroidal transformer by any chance has someone salvaged one out of something that is readily available, like possibly a copier or something,
I want to connect it to a PMDX135 either 50V or 80V, which PS would be better for running 4, PK296A2A-SG7.2's and what should the power rating of the toroid be, (max voltage x max current) of the PS? or is that over designing, cause a 1600 watt toroid might be expensive.
This information might already be in a thread somewhere but I only looked for about about an hour and didn't find any concrete answers.
Mitch
Old Fri 06 November 2009, 15:40
https://www.antekinc.com/
Best source for Transformers and power supplies.
Old Sat 07 November 2009, 05:52
I use a 25VAC transformer (~35VDC) when I wire PK296A2A-SGxx motors half-coil. You could go just a little higher (28VAC = ~39VDC) before you have to worry about excess heat. Each motor pulls up to 3A, so 3A X4 = 12A. 12A X 25VAC = 300VA.
I've used both a 250VA and a 500VA transformer with 4 PK296A2A motors. Both sizes worked just fine.
The second MM was easy, but the building's electrics were noisy #28 - Orlando, FL smreish MechMates already cutting 58 Sat 26 September 2020 17:36
Fire, how easy it is to start one! smreish 55. Dust Management 8 Sun 10 October 2010 20:22
Transformer Selection KenC 702. Power Supplies 2 Tue 21 July 2009 06:14
Timing pulleys made easy stcnc The Market Place 0 Mon 08 September 2008 15:02
Moving from SB to Mach software is it really that easy or good Gerald_D Archives 45 Mon 09 October 2006 21:28
