Old Tue 04 March 2014, 01:23
racedirector
Just call me: Bruce #122
New South Wales
Nice negotiation, you sell cars by any chance - ha! Glad you sorted Mod 1 stuff, mod 2 wouldn't have worked as it would have put the rack teeth 5mm further down making the motor swing not work. Everything Gerald designed has matching pieces that if we go changing things it has consequences
BTW, I got my Z steel (100x6x750 Cold Rolled Flat) from Bright Steels in Melbourne, 03 9587 0307. Couldn't find anything like it in Sydney, goodness knows why ?!?!?
Last edited by racedirector; Tue 04 March 2014 at 01:27.. Reason: Spelling of course!
Old Tue 04 March 2014, 03:35
Bazza
Just call me: Bazza
South West Rocks
Hey RD
Thanks again
I'll give them a bell tomorrow
Regarding the rack dimensions, I'll need to re-read the various threads through properly to fully comprehend the sizing rationale rather than their physical dimensions.
Makita Cold saw on order, my workshop is growing by the day (only 27 left)
Bazza
Old Thu 29 May 2014, 01:28
Bazza
Just call me: Bazza
South West Rocks
Moved Home
Just picked up my steel for the table, slowly but surely
Old Fri 20 June 2014, 22:30
Bazza
Just call me: Bazza
South West Rocks
Slab poured yesterday
Now doing the mark out for my workshop!!
Bazza
Old Fri 12 June 2015, 21:59
Bazza
Just call me: Bazza
South West Rocks
Been a bit quiet of late but in my spare time, I tried to work on my very limited knowledge of stepper motors, drivers and Toroidal power supply
I ended up making a spreadsheet to assist in learning the difference between Unipolar (U), Bipolar series(S), Bipolar half coil(H) and bipolar parallel(P)
Immediately noticed some of the stepper motor specs refer to different wiring configurations
I am going to wire my motors bipolar Parallel (most efficient for torque and speed) looked into 4 stepper motors and it came down to these two
If my spreadsheet is right:
KL34H295-43-8A advertised as having 960 Oz/in but only if wired S and P therefore 640 Oz/in wired U
34HS9801 advertised as having 490nM (693 Oz/in) specked in U and therefore 980 Oz/in wired in either S and P
Please correct me if I'm wrong here as its the basis from which I can move forward.
I also included a method of selecting a variable power supply using between 1-9 motors with 3 stepper motor candidates in any wiring (H,U,S&P) configuration
This is where I need help
I have made these assumptions:
The amp draw (A) and total capacity (W) change with the number or motors added but the voltage is is rated against just the maximum draw for 1 motor?
Bazza
Old Tue 16 June 2015, 18:16
Bazza
Just call me: Bazza
South West Rocks
OK
I have started a new shopping list
Just ordered and received my 2.2K Watercooled spindle and VFD
I'm about to plonk some doe down on 4 x 3hHS9801 MotionKing stepper motors
I want to wire them bipolar parallel and incorporate a 3:1 belt drive running a 30T Pinion
My spreadsheet with the modified inputs give (P) 829VA, 55VAC @10.6 amps
From this Antek's PS-8N56 - 800W 56V Power Supply looks like a close match (but out of stock)
I'll email them and:
1) Ask if the motors and toroidal match
2) when they are back in stock
Had a look into the drivers and can't afford the Gecko 203V and reckon the Leadshine DM856 looks like a good compromise
The PMDX-122 breakout board looks popular so I'll go with that
My revised list of MM stuff is
All the metal for the table and gantry
The laser kit and skates
Rack and pinions
V rollers and offset bushes
Cold cutting drop saw
inverter stick welder
Pedistool drill press
Milwakee grinder
Still need to locate tool steel
Bazza
Old Wed 17 June 2015, 02:12
RifRaf
Just call me: RifRaf
NSW
you can find tool steel in AU at places like gasweld or where lathes etc are sold. or search ebay for HSS Lathe Tool Steel . since have not bought any tool steel for my build yet am not sure what size you need and might not even be what you are looking for
Old Wed 17 June 2015, 05:48
I think Bazza means Gauge Plate, for the Z slide.
I could not get it here.
I used ordinary plate.
My build was a compromise from start to finish.
Getting on for 2 years now and no major problems.
Old Wed 17 June 2015, 18:15
Bazza
Just call me: Bazza
South West Rocks
Hi Rifraf and Al
Thanks for your advice
About a year ago I undertook a search for suitable Z slide material calling it unhardened flat bar tool steel.
I was sent this data sheet by one company
FGS Data Sheet.pdf
I know very little about this subject and from memory my dimensions of 100mm x 6mm x 750mm was problematic
I got your PM Rifraf and will reply neighbour!
Bazza
Old Thu 25 June 2015, 22:26
Bazza
Just call me: Bazza
South West Rocks
Well
Ive been doing some more research
It never ends!
Having trouble getting in touch with ANTEK, sent an email a week or so back with no reply yet
However, I noticed something in their specs that has now changed my toroidal power supply....I Think?????
My specs are for VAC, I see they(Antek) spec VDC
Therefore: VDC = (VAC x SQRT2)
VDC = 55 x SQRT2= 77.7VDC
Here is my second email to them:
"Hi
A week or so back I asked your advice on which Toroidal power Supply would suit a Mechmate CNC Router
The stepper Motors will be (wired Parallel) 4 x 34H2A9840 (used to be known as 34HS9801)
The drivers will most likely be 2LD880H (can handle 80VAC)
I originally thought your PS-8N56 would suit but realised the 56 was VDC
I now think the PS-8N77 would be far more suitable
My questions are:
What size would you recommend?
How much is the shipping cost to ......."
I also got in-touch with Motionking and found out a few things
Their 34HS9801 is now called 34H2A9840.
I am looking into their 2LD880H driver as it will take up to 80 VAC (113VDC)
Also asked if the make breakout boards similar to PDMX-122
Bazza
Old Wed 08 July 2015, 02:39
Bazza
Just call me: Bazza
South West Rocks
After weighing up all the possibilities I have gone with the following from Motionking
Their response:
"It's OK to separate them. Pls see
* 4 pcs stepper motor 34H2A9850 , $55.00/pcs -------- $220.00
* 4 pcs 2LD880H , $62.00/pcs -------------------------------- $248.00
* 1 pc Breakout board , $15.00/pcs ------------------------- $15.00
Express Freight, $160.00"
All in USD
The stepper motor model numbers have changed (used to be 34HS9802)
Put an order in with Antek for PS-8N56 (they will have more units from mid to end of this month)
So another chip away at the mountain
Bazza
Old Wed 12 August 2015, 17:02
Bazza
Just call me: Bazza
South West Rocks
Well after a very long wait for the product to be restocked I received my Toroidal power supply, the Antek model PS-8N56
Adrienne kindly gave me a discout to compensate for the drop in the AUD whilst waiting
Looks great
Next control box and wiring!
Not entirely sure what dimensions I need but I guess I'll lay out what I have and guestimate
Bazza
Old Thu 13 August 2015, 07:03
racedirector
New South Wales
Bazza, go bigger than you think you need with the control box, you'd be surprised how quickly the damn things fill up. Always better to have some room to run the wires nicely.
Old Thu 13 August 2015, 19:20
Bazza
Just call me: Bazza
South West Rocks
Thanks Bruce
I'm going to visit a wholesaler this afternoon and try for the largest
Also need to get my wiring
I have all the metal so my next job is to cut it!
Not sure whether to cut back the rust formed now or later (live within 1km from the sea)
I'll start posting up pictures soon
Bazza
Machining Aluminum #122 - Sydney, Australia racedirector MechMates already cutting 735 Mon 22 June 2020 00:38
Laser cut and formed parts - Australia MattyZee The Market Place 23 Sat 04 June 2011 06:21
On to parts Ordering - Matthews NC USA qroger Construction started, but not cutting yet 51 Mon 11 October 2010 05:07
parts finding - Victoria, Australia ozzieboy26 Introduce yourself and start planning 4 Tue 11 May 2010 20:56
Ordering parts: Marysville, CA-USA MachineMonkey Construction started, but not cutting yet 7 Fri 13 March 2009 18:45
