Old Wed 08 July 2009, 21:03
Conrado, I would first use the 42VDC for the PK296a2a-sg7.2 motors. If they get too hot to your liking, you can set the Gecko currents a bit lower.
Old Wed 08 July 2009, 22:22
Conrado_Navarro
Just call me: CONRADO NAVARRO #55
OBREGON
Mexico
Send a message via MSN to Conrado_Navarro Send a message via Yahoo to Conrado_Navarro
Ok Mike, thats why I wanted a pciture of the PMDX 122, to check against mine.
Thanks G. Ill check... so far, no warmig at all
Old Wed 08 July 2009, 22:53
The G203V drives are very good at keeping the motors cool while they are not doing any work. The real heat comes when the motors have worked at their current limits during high speed and high load (taking a long hard cut on a very long table).
Other brands of drives, and older Geckodrive versions, would sometimes create the most heat when the motors simply stand still. With the more intelligent drives, it is now more difficult to test when the voltage (or current) settings are too high. I think it is okay if your motors get hot for some heavy jobs - but most of the time they will just be standing still and cooling down (if they have a G203V drive).
Old Wed 08 July 2009, 23:11
Conrado_Navarro
OBREGON
Mexico
Gerald/Mike
I reinstalled the PMDX122, its the same, J8 to ground 5V, Step to common 1.3V
check the geckos step to common 1.3V, Power to Ground 42 V,
motors cool, cant move by hand while connected, MACH3 running but no movement.
All the ligths are steady green
Old Wed 08 July 2009, 23:24
Conrado_Navarro
OBREGON
Mexico
image with all the ligths green
Old Wed 08 July 2009, 23:57
Conrado, I believe you need to set up some more in Mach3's Ports & Pins.
When you use your keyboard cursor keys to move left/right or up/down, the green leds for Direction should go on and off.
Have a look at:
Cannot get motor to turn - Mach Ports & Pins setup
Motors won't turn after the setting up - PMDX-122 jumpers incorrect
Stepper motor refuses to turn - Wiring & jumper errors
Old Thu 09 July 2009, 01:04
Gerald / Conrado,
It has been some time since I wired my machine but I think I see another problem. There are 4 Geckos, X1, X2, Y, Z but yet you are using J1, J2, J3, J4. I think X1 and X2 should both be going to J1?!
Old Thu 09 July 2009, 05:01
Nils, it doesn't make much difference either way, depends on whether one has used the "Slave" setting in Mach3 or not. If you look at our control box, you would see that we have also wired like Conrado, and used the Slave.
Sean left J4 open on yours for adding an indexer later, but then you are not using the Slave.
Both approaches work okay.
Conrado's problems were solved - all the related posts were moved to the Troubleshooting forum at:
Motors do not turn - Ports & Pins setting for charge pump
Old Tue 04 August 2009, 16:30
Conrado_Navarro
OBREGON
Mexico
Hello.
I´m finishing the Z slide. but its almost imposible due the temperature this summer, very often is above 50 degrees celsius (Fahrenheit 122).
Workshop needs to modify because where I have the table the cover is missing.
Will post progress later.
Old Wed 05 August 2009, 01:45
Conrado,
Great progress.
I thought it was hot in my shop when it is in high 90s. With the humidity it does feel hotter but 122 - that is hot.
Old Wed 05 August 2009, 07:49
Conrado_Navarro
OBREGON
Mexico
yes, I only work in my workshop only half hour at the time. and go back to learn cad-cam software. and of course read every post in the mechmate site.
best regards Nils
Old Wed 05 August 2009, 12:24
kanankeban
Just call me: Hector #89
Monterrey
Mexico
Originally Posted by Conrado_Navarro View Post
Hello.
And I thought I was in hell with 41 degrees celsius!
Old Fri 11 September 2009, 20:34
Conrado_Navarro
OBREGON
Mexico
Gerald and company.
the beast is almost finished.
I have one question. is it right to connect the router direct to the pmdx 122, J7 relay control?
it is rated at 10A at 120V, and my router is 8A 120V rated?.
Old Fri 11 September 2009, 21:48
Conrado, in theory it is okay.
However, you can expect that relay to last maybe a year before it burns and then you will have to find a way of replacing it. That is why we prefer to switch the big current in a separate relay - we use the PMDX relay to switch the separate relay
Old Sat 12 September 2009, 07:46
Conrado_Navarro
OBREGON
Mexico
Thank you!!
Got it. its a very good reason to use a heavy duty relay.
soon this weekend. a mechmate in Mexico will be alive!!
Best regards!
Old Sat 12 September 2009, 07:57
Conrado,
Sounds great... Look forward to seeing some pictures.
Old Sat 12 September 2009, 09:59
Conrado_Navarro
OBREGON
Mexico
Nils.
Sorry for not posting pictures till now. but soon....soon!!
Old Wed 16 September 2009, 18:34
Conrado_Navarro
OBREGON
Mexico
Mexico's 1st Mechmate Finally is cutting!!!
only need fine tunning, but it surely cut. Its not the most beutiful MM but I made it myself. whit zero background. less money and little time.
Thanks Gerald, Mike, Nills. and all who post their troubles because of them, I made it!!
gee I fell like I win the Oscar.. hahaha.
Again. Thanks!!!
Old Wed 16 September 2009, 19:54
Hey Conrado, felicitación
No Oscar...Of course not, better yet...You won huge pride and self reward....ALOT BETTER than any celebrity’s trophy
Great to see ya’ll excited dude...Now, show time…. WHERE….ARE…THOSE…PHOTOS
Surly I speak for Everybody else, we needs to see this buddy.
Amicalement, Robert
Old Wed 16 September 2009, 19:59
Conrado,
Slap some logos on the thing so you can get a number. Congratulations. If you gained some knowledge from my post good. Now, how about posting some pictures.
Old Wed 16 September 2009, 21:56
Conrado_Navarro
OBREGON
Mexico
Yea guys you surely deserve photos!!!, cable chain is missing, waste board, and labor quality in not the best... but... cutting quality is wort at least 10,000 dlls. (similar sizes tables in market & less cutting area and etc).
thanks for your comments!
Old Wed 16 September 2009, 22:59
Fantastic Conrado!
Because of all the silly movies at the cinema, I have this picture of a guy with a big hat dancing on a table!
Old Thu 17 September 2009, 14:19
kanankeban
Monterrey
Mexico
Again. Thanks!!!
Hey, Congratulations, thought mine was going to be the first one in Mexico, but I havent invest time lately on the construction, I can say that is already painted with a beautifull sail blue color., just need motors&gears and time to build the control box and thats it...Well second is good also...
Old Thu 17 September 2009, 15:24
jehayes
Just call me: Joe #53
Whidbey Island, Washington
Conrado: Felicitaciones en su consumacion. Ganaste el premio! Joe
Old Tue 27 October 2009, 19:22
Conrado_Navarro
OBREGON
Mexico
my mechmate still goig strong, the machine does exactly what must do
tomorrow I will cut some kayak parts, Im plannin to take photos to show you guys.
still missing cable chain, and beauty work,etc. but works prrrfct.
Old Tue 27 October 2009, 22:37
I am glad (but not surprised) that you are still a happy man!
Old Wed 28 October 2009, 12:23
Conrado_Navarro
OBREGON
Mexico
Hello:
Im posting a few pics of my machine, still working on it
this is my supervisor
Old Fri 30 October 2009, 09:01
Conrado_Navarro
OBREGON
Mexico
Hello
this is an image of the kayak im machining.
I have the file in solidworks.
Work is comming by itself, Yesterday an Aluminium Sign and a foam fish in 3d, today a wood carving.
Kayak is a work in progress.
cheers
Old Fri 30 October 2009, 09:11
bradyaero
Just call me: Greg #19
Smiths Falls, Ontario
Nice work Conrado,
Its great to see other mold makers on the forums!
Old Fri 30 October 2009, 10:32
Conrado_Navarro
OBREGON
Mexico
thanks Greg
Im New to everything, but I like to try.
It Cuts the Wood and Aluminum #76 - Guadalajara, Mexico rceja MechMates already cutting 85 Sun 17 November 2013 06:26
It runs! #89 - Monterrey, Mexico kanankeban MechMates already cutting 118 Tue 17 January 2012 18:42
Mechmate Parts for sale w/photos. Finally stphnd22 The Market Place 14 Wed 07 September 2011 20:25
Mechmate cutting in Puebla TimWerding Introduce yourself and start planning 3 Sat 21 May 2011 08:25
3D Elk cutting (video) #13 - Hagerman, New Mexico Greg J MechMates already cutting 415 Sat 05 September 2009 20:28
