Old Sat 18 May 2013, 05:07
tangocharlie123
Just call me: Pete
Gatton Brisbane
Low riding dust shoe
Has anybody thought about or designed a dust shoe that basically rides just above or on the sheet board that you are cutting.
I am thinking of cutting small pieces of 3 mm MDF and have the possibility of them lifting with a 1.5mm spiral upcut bit.
any thoughts
I was thinking of making it from sintra or the like with PU underneath for it to slide on.
Peter
Old Sat 18 May 2013, 16:31
rcboats1
Just call me: Kelly
Everett (WA)
I believe you are talking about a pressure foot. I haven't used one but have heard of them.
Old Sat 18 May 2013, 20:45
tangocharlie123
Just call me: Pete
Gatton Brisbane
Thanks Kelly
found out about them at 2am this morning.
I found the widget works and have emailed them for further info. I belive that this may have to be modified someway
Old Sun 19 May 2013, 08:17
parrulho
Just call me: Paulo #108
willemstad
Netherlands Antilles
Links that maybe of interest to you?
http://www.mechmate.com/forums/showt...&postcount=170
look at the youtube link.
Old Mon 20 May 2013, 15:56
polishpickle
Just call me: Jerry
Medina
I built my own I used some colorcore scrapes for the foot and plexi for the plate.
Old Mon 20 May 2013, 16:11
rcboats1
Just call me: Kelly
Everett (WA)
Good deal. How about some pictures?
Old Tue 21 May 2013, 04:39
nisma
Just call me: chris
bz
Italy
This is for the Z axis, i like the idea of attaching it with magnets.
Using of clear pcv is a option instead of using the brushes.
http://www.el34world.com/misc/cnc/CNC20.htm
The alternative that you probably want is something like this:
http://cncmentor.com/wp-content/uplo...oot_trans1.jpg
This type should work better, the downside is that itīs really better to not have any
collision or wrong thickness of the board, so itīs not for everyone.
Old Tue 21 May 2013, 07:02
http://www.google.com/imgres?imgurl=...9QEwBQ&dur=396
This is a "pressure foot" with dust collection for a Multicam 1000 series machine. WORKS! The foot is spring loaded and has a delrin pad on the bottom for constant contact with the sheet of material being cut for the scenario discussed.
I owned one for many years and can say it was one of the best features on my Multicam.
Old Tue 21 May 2013, 07:25
I also like the cyclone/vortex style of that foot using only a 2" hose.
Old Tue 21 May 2013, 11:16
polishpickle
Just call me: Jerry
Medina
here is a pic
Old Tue 21 May 2013, 13:25
polishpickle
Just call me: Jerry
Medina
here is another shot
Old Wed 22 May 2013, 15:06
tangocharlie123
Just call me: Pete
Gatton Brisbane
Thanks Jerry and Sean both are exactly what I am looking now just need to design exacly what I need as the machine that it is going onto has the ram and slide for the dust shoe on the right of the spindle.
If I was to rotate the Multicam unit to the right orientation the suction hose would come out under the gantry.
Sean how did you select your springs did you use a formula or was it by trial and error.
one other issue that we have on this machine is that the whole unit needs to drop 50mm below the nose of the tool holder to accomadate an ATC.
with thanks
Peter
Old Thu 23 May 2013, 08:35
Gerald, the 2" dust collection hose was great.
I was able to get a very flexible - and light - dust collection all around the table with a single little swing arm on the ceiling.
ATC challenge.
Go to multicam's website and do some research. The machine I had did have an ATC option with this shoe. I haven't a clue how it worked to clear away for a tool change.
Old Sun 02 June 2013, 19:46
tangocharlie123
Just call me: Pete
Gatton Brisbane
Thanks for the info Sean
The dust shoe / Pressure foot arrived from the MultiCam/MatCam distributor here in OZ
Took a couple of hours to install and had to wait a day for the ducting to arrive it's all up and running made a new smaller foot ie less of a hole as we still lost some small pieces.
The ATC has been removed now as it was a trade off better machining or a couple of minutes resetting the cutter the latter won.
Will look at getting smaller diameter hose to run all the way back to the dust extraction later.
Old Mon 03 June 2013, 01:04
Pete,
Would you please post a photo! Thanks
Old Mon 03 June 2013, 06:48
Pete. Great news! Glad I could help. I "loved" that dust collection foot more than any other I have ever used. I trust it works well for you too.
Best,
Old Thu 13 June 2013, 09:54
GeoffreySharp
Just call me: Geoffrey
Scranton
ATC challenge.
Thanks for small review. I have been searching some information about 2" dust collection hose and I think I need to get it now. Thanks again
Old Mon 17 June 2013, 15:12
tangocharlie123
Just call me: Pete
Gatton Brisbane
After a couple of weeks of use I love this pressure foot. I have not lost a part since using it.
photo's as requested
prior to install
Installed on the z axis, it had to be relocated as the old dust foot was on the right.
It came with two collars one for the brush and one for the pressure foot. As the hole was to big I cut a new one from the nylon chopping board. (now to explain the round hole)
Once again thankyou everyone for thier input. this forum is so great for informative people.
Peter
Old Mon 17 June 2013, 15:14
...I told you that was the BEST foot I have ever used on a CNC machine!
Glad you like it.
It's not the most inexpensive - but works super well.
Cheers.
Has Logos and Cut A Dust Shoe! #78 - Mississauga, CANADA loubozzelli MechMates already cutting 28 Mon 03 October 2011 16:28
Dust shoe on UTube Art 55. Dust Management 4 Sun 04 July 2010 06:09
Axial dust shoe PEU 55. Dust Management 11 Thu 24 June 2010 10:03
Dust-proofing stepper motors and consequences of dust ingress Doug_Ford Motors & their mountings 25 Thu 08 November 2007 19:09
Handmade V-Rails - "JR Skate" has 4.5" grinder riding the rail J.R. Hatcher Archives 93 Tue 23 October 2007 09:37
