Old Tue 17 January 2017, 14:20
st_indigo
Just call me: Philip.X.Diaz #123
Los Angeles, CA
My awesome acrylic dust shoe design
Hey all. I finally got around to designing a proper dust shoe for Mechmate #123 and after using it a few weeks I can confirm that it is a solid design. I love it when a plan comes together.
Photo of it installed:
...and this is what the parts look like:
Brush strip was ordered from McMaster Carr. A 3 ft length is the perfect amount for this dust shoe.
Notes:
- Acrylic was used for visibility; Thickness isn't critical but use at least 0.25" thick material for stability; I used 0.33" acrylic that I had leftover from another job
- The upper portion is attached to the Z-slide via a 2" piece of aluminum angle
- The lower portion is attached to the top via 6X 10mm neodymium magnets epoxied into the milled recesses; Double check your polarity before you glue those magnets in!
- There is also a semi-circular front to the lower shoe that I haven't attached yet; I am going to use short pieces of brass rod epoxied into the semi-circle with matching holes drilled into the lower shoe so it is removable
- Brush strip was attached with self-tapping screws; pre-drill your holes so you don't crack the acrylic
- Dust hose fitting is secured with a drilled hole and a #8 machine screw (visible in the first photo at the bottom of the dust hose)
- Make sure you reset your max Z+ limit so your shoe doesn't get ripped off if you jog your Z too high
Questions? Hit me up. Vector PDF is included so you can make your own.
Rock on, Mechmates.
Old Wed 18 January 2017, 08:30
Kornerking
Just call me: Pete #127
Big Falls, Mn
Kool. I just came in to look for plan for a dust shoe and here it is.
Perfect timing.
Old Mon 10 April 2017, 21:24
firechief
Just call me: Tim
Battle Creek
How does the z go to home? the shoe will hit the v wheels
Old Sun 16 April 2017, 20:07
you can set the z home in mach 3 and also set the safe z parking position.
Old Thu 27 April 2017, 23:03
IamDave
Just call me: Davey
Ball Ground, GA
I use Kents Dust shoe on my machine now. I really like this design with the ability to see the bit. With a spindle not an air blowing porter cable.
Low riding dust shoe tangocharlie123 55. Dust Management 18 Mon 17 June 2013 16:14
Has Logos and Cut A Dust Shoe! #78 - Mississauga, CANADA loubozzelli MechMates already cutting 28 Mon 03 October 2011 17:28
Dust shoe on UTube Art 55. Dust Management 4 Sun 04 July 2010 07:09
Axial dust shoe PEU 55. Dust Management 11 Thu 24 June 2010 11:03
Dust collection piping design & supply Gerald D 55. Dust Management 2 Fri 03 October 2008 11:53
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
