Old Wed 10 July 2013, 19:11
Red_boards
Just call me: Red #91
Rail wear after 1 year
My machine does not work very hard (half dozen hours a week), but after a year or so I've noticed a sharp lip on the rails at the bottom of the vee (i.e. where the vee meets the vertical wall of the rail) - like the burr you get on a knife edge if you over sharpen one side.
I'm assuming that this is wear from the hard wheels pushing down on imperfectly angled vee rails. Can I harden the rails by blow torching them? Is the wear likely to progress to the point where the wheels pinch? Any ideas or recommendations?
Old Wed 10 July 2013, 23:18
We also got that sharp ridge. After keeping an eye on it for a while, to see if it got out of hand, we decided that everything was stable and then just left it alone.
You can only harden steel if it has enough carbon in it. The carbon content of plain angle iron is too low to harden.
Old Thu 11 July 2013, 23:25
racedirector
Just call me: Bruce #122
New South Wales
My current CNC (not a MM) uses the same principle and has those ridges too. The wear seems to stop after a while and settle down. Unless it starts introducing errors into your work I wouldn't worry about it, generally is just means the angle is settling into the trafic it has across it.
Bruce
Old Wed 24 July 2013, 20:27
Red_boards
Thank you for the responses. Leave well enough alone, then
Old Wed 24 July 2013, 22:36
Mine has the same thing.
Happy New Year 2011 decibel Miscellaneous / General / Whatever / Catchall 7 Fri 31 December 2010 22:11
One year later - a report back #29 - Manitoba Canada astrolavista MechMates already cutting 33 Fri 13 August 2010 14:58
Happy New Year for 2010! Gerald D About this Forum 25 Sun 03 January 2010 13:03
A year of lurking pays off - Montesano, WA lumberjack_jeff Introduce yourself and start planning 20 Tue 25 August 2009 22:38
