Old Sun 21 August 2011, 03:57
casi
Just call me: veni
prishtin
rack and pinion in Macedonia
Hello does anyone know where can I buy rack and pinion in Macedoni.
Old Mon 22 August 2011, 06:53
Kalmfist
Just call me: Ljupcho
Skopje
Macedonia
Story of my life!
It`s hard to find anything. Almost everything you need to buy on line, (of-course, if they ship to Macedonia).
Maybe, there are some small shops that I don`t know.
The only thing that I find is one person from Kumanovo, who probably got some Chinese things, steppers, drivers... He also got some racks and pinions.
Link : od pazar 3
you can send him an email.
Not so cheap, but that is all you got.
If you find anything please tell.
Ave!
Old Mon 22 August 2011, 10:44
You can contact LAGERTON from Niš , Serbia . they got metric module 1 rack and 20-30 tooth pinions
Old Fri 02 September 2011, 14:40
casi
Just call me: veni
prishtin
Thanks a lot for the help guys.
Danilo I contacted this firm and now I have bought rack modul 1 and pinion modul 1 20 teeth , thank you for your help.
Casi
Old Fri 02 September 2011, 14:42
I don't know your setup but if does not include some kind of reduction drive 20 tooth will be a bit rough, 3:1 reduction and 30 tooth pinion is what works for me
Old Sat 03 September 2011, 03:46
casi
Just call me: veni
prishtin
I am using direct driven stepper motor without reduction.
Old Sat 03 September 2011, 04:32
My mistake 20 tooth gives more precision than 30,
but without reduction ( 20 * PI ) / 200 steps = ~0.3mm positioning accuracy
no matter how much microsteps the drive has it can not position accurately in microstep.
Its no problem you can start without reduction and add it later if needed.
Old Sat 03 September 2011, 08:53
20 teeth pinion, module 1, metric, is a little bit small to drill out for 12mm shaft and then still get a locking screw in there. 24 teeth is usually okay.
Old Sat 03 September 2011, 08:59
I see your motors Veni have 14mm shaft just like mine, so watch out for that also as Gerald noted.
My 20 teeth belt reduction pulley had a 16mm collar so I welded another one over that so I can put a grub screw there. Was lucky to get an iron pulley not the aluminium one.
If you ever opt for belt reduction look here for those pulleys
http://www.kumakis.rs/sajt/
Old Sat 03 September 2011, 12:35
casi
Just call me: veni
prishtin
Thanks Gerald thanks danilom, exactly this is the problem what I have now because I have not noticed that my motor shaft is bigger than inside diameter of pinion.
Old Sat 03 September 2011, 13:00
I measured the 30 tooth pinion and its 20mm, so I will have only 3mm for grub screw if mounted directly on the motor shaft.
Rack and Pinion Suppliers: Outside the USA Gerald_D Driving Mechanisms: Rack/pinion, gears, screws, belts & chains 81 Mon 14 May 2018 02:50
Rack and Pinion Suppliers: In the USA fabrica Driving Mechanisms: Rack/pinion, gears, screws, belts & chains 87 Sun 08 March 2015 18:04
rack and pinion specs?? tldj55 General - MM Build 1 Sat 15 January 2011 12:55
Rack and pinion question albertoslayer General - MM Build 11 Thu 25 February 2010 08:27
Need help with rack dimensions :( - Bitola, Macedonia gorantec Driving Mechanisms: Rack/pinion, gears, screws, belts & chains 4 Fri 10 April 2009 07:19
