Old Tue 08 December 2009, 11:39
MariusL
Just call me: Marius #22
Centurion
Clamping device for small jobs
I developed a need for a clamping method for doing small jobs that are repeated many times. This is the clamp thing that I came up with, it works very well. If you paint it you can use it to cut aluminium and steel with a lubricant or coolant. The MDF will not damage.
I sealed all the parts first with a water based sealer and then painted it with a hammer tone finish. There are some ugly marks on the thing because I could not wait for the paint to dry properly.
I had to cut this 3D clock for my wife and then do the pocket at the back.
Following are some pics of the parts. Note the inserts used - 8mm self threading insert and a 8mm "T" nut or furniture nut.
Old Tue 08 December 2009, 17:11
lumberjack_jeff
Just call me: Jeff #31
Montesano, WA
I like this a lot.
Old Tue 08 December 2009, 20:50
liaoh75
Just call me: David
Taibao
Taiwan
Cool Idea! Thanks for sharing!
Old Tue 08 December 2009, 21:50
MariusL
Centurion
Pleasure is mine. I forgot to mention the material is 30mm MDF. You can see the tool sizes from the G-code.
Old Wed 09 December 2009, 00:40
Thanks Marius, that looks much nicer than my thrown together bits and pieces I have used in the past.
Old Wed 09 December 2009, 04:07
Very nice looking slot table. Thanks for sharing
Old Wed 09 December 2009, 07:08
Claudiu
Just call me: Claus #43
Arad
Romania
Very useful. Thanks for the files.
Canīt wait to have MM up and running, I got so many Projects to do....
Old Wed 09 December 2009, 22:37
MariusL
Centurion
Claus believe me once you have the machine the projects multiply.
Old Wed 02 April 2014, 20:54
jayrdwein
Just call me: jayr
canberra
That's so nice! The slot table looks so perfect in every way that is why it is obviously very useful.
Old Thu 03 April 2014, 02:14
MariusL
Centurion
MDF is magic stuff. I have made many tools using MDF.
Old Thu 03 April 2014, 14:45
Nicely done.
Old Fri 08 August 2014, 02:56
tangocharlie123
Just call me: Pete
Gatton Brisbane
Hi is anyone having trouble D/L the above zip file
thanks
Old Fri 08 August 2014, 05:01
MariusL
Centurion
Just tried, it works. PM me I will send it to you if you dont come right.
Old Fri 08 August 2014, 12:58
IMMark
Just call me: Mark #119
Columbus Ohio
I just grabbed it. Works for me?
Thanks Marius for the file! When I first saw your post, I thought you had based your wooden table on the metal one...then realized that the metal one, is the wood painted
Thanks again
Mark
Old Fri 08 August 2014, 22:27
MariusL
Centurion
You're welcome man. I painted the unit with a hammer tone finish to seal it all round as I was cutting aluminium that needed some coolant. That was the only paint I had at hand.
A very simple sanding device gixi Miscellaneous / General / Whatever / Catchall 2 Mon 29 June 2009 07:14
Cam Type Clamping Fixture Rad Racer General - MM Operating 0 Sun 05 April 2009 21:55
Small World or Not Kobus_Joubert Archives 0 Fri 25 January 2008 11:37
V-Rail profiling device - an alternative skate design Atifeh Rails & Rollers 9 Fri 25 January 2008 09:12
Small problems Admin Test Area for this forum 14 Sat 02 June 2007 23:41
